Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Help: installing HKS SSQV BOV
Old Jul 20, 2011 | 06:34 AM
vics(evo8)'s Avatar
Hey guys, i recently received a gift of a HKS SSQV BOV Limited edition. It's exactly the same the difference is that it's just black. I've been very confused because i know we have a recirculating system, and these BOVs do not have that. we have two pipes that connect to the OEM BOV. the HKS only has one input. If any one can help i would really appreciate it. thank you.
Old Jul 20, 2011 | 06:51 AM
Ev0ikon's Avatar
I suggest you not to use that valve.
Old Jul 21, 2011 | 01:02 PM
Kanweezy's Avatar
I'm running a non recirced hks ssq, and just use a flange and connect to the pipe that leads to the front of the engine and cap off the other with a plug of some sort
Old Jul 21, 2011 | 01:03 PM
Kanweezy's Avatar
Mine was recirced at one point but no more
Old Jul 21, 2011 | 03:39 PM
sideway180sx's Avatar
you can buy the recirc. kit for the hks bov.
Old Jul 21, 2011 | 03:58 PM
MaLo EvoVIII's Avatar
Do you know how much they paid for the blowoff valve? Was it purchased on ebay?
Old Jul 21, 2011 | 08:14 PM
sotxEvo's Avatar
i had the 2nd gen hks ssq and if i remember correctly it was supposed to hold up to 30 or 32psi...it would crap out over 25psi. just my 2 cents.
Old Jul 22, 2011 | 07:20 AM
ProjectGSX's Avatar
Cap off the intake port. You can vent to atmosphere, you will just run rich after shifting as a result. Make sure the valve is closed at idle by adjusting the spring tension.
This is not the recommended BOV set up for the Evo. I ran a similar set up on my old Eclipse GSX and never had a problem with it. Your mileage may vary.
Research BOVs.
Old Jul 23, 2011 | 05:13 AM
vics(evo8)'s Avatar
Thanks guys, the BOV was bought for about 120 shipped and yes it was from eBay. The man had a perfect feedback so I guided my self by that. In adittion, he had sold over 50 of them as a Result, if anything was to happen I think it's enough products sold for someone to complain about them. I'll research what u guys where tellining me of the recirc kit. Thanks again
Old Apr 2, 2012 | 12:35 AM
AvenGerMK's Avatar
HKS SSQV Racing BOV Single Valve
just wondering if anyone knows anything about installing this particular blow off valve? i dont know what flange i need to install it. theres steel mild steel aluminum and different sizes. im not the master mechanic id like to be but i cant find any indication as to what metal and size i should get. usually id assume the bigger the hole the better but i do not know. and my mechanic wasnt any help. he just said to get the flange. also if you know where i could get the flange sooner than 4 months later from hks japan that would be awesome. tuning a new car is always such a joy....
Old Apr 4, 2012 | 06:07 AM
bandalgom78's Avatar
Don't use it...I did installed it and returned it.
HKS is good products....but for evo x not...BOV...
akqowns
Apr 17, 2014 08:40 AM
chundizzy
Apr 10, 2014 08:38 PM
HPEVOX
27
Apr 14, 2010 06:23 PM
hoongss
11
Aug 28, 2009 02:45 PM
RyanM
Aug 9, 2005 09:52 PM
