HKS SSQV Problem
Old Nov 13, 2011 | 10:37 PM
Evo8*'s Avatar
HKS SSQV Problem
So I just installed my newly acquired SSQV. I am 100% certain I have done everything right... but as the revs come down the car tries to stall, and a blip of the throttle is required. I've rechecked my hose clamps and pipes but still have the same problem.
It was running fine when I had the stock recirculating valve in there...
Any ideas...?
Old Nov 13, 2011 | 11:00 PM
Agetec's Avatar
The hks is recirculating right?
Old Nov 13, 2011 | 11:08 PM
USCGSAM's Avatar
From: Detroit metro area Michigan/Washington DC metro area
Any ideas...?
BUMP for this i have the same EXACT problem with my agency power BOV and its IS recirculating, sometimes pulling up to red lights it'll start to stall, even in neutral. a quick blip on the throttle then a rough idle it settles back down. its completely random as well no pattern at all.
Old Nov 13, 2011 | 11:11 PM
civicej8's Avatar
as long as the car doesnt die then its normal. either get the recirc kit or just learn to deal with it. if you let off of the gas before you push in the clutch then the rpms wont drop. try that.
Old Nov 13, 2011 | 11:52 PM
turbotalawd's Avatar
If you like your cars running like that then i guess its "normal".
If you want to fix it, put the stock bov back on or convert to speed density. Even with the recirc it will still run wrong.
Old Nov 14, 2011 | 12:53 AM
EcHo714's Avatar
check the vacume lines
Old Nov 14, 2011 | 03:45 AM
Evo8*'s Avatar
No, it's not recirculating. I was thinking maybe the recirc kit would help, but turbotalawd says otherwise... I really don't see what the issue is though... Unless the valve is staying open too long, maybe that's it?
Old Nov 14, 2011 | 03:52 AM
Evo8*'s Avatar
After more driving and experimenting with different level and throttle, I am actually getting slight surging (flutter). Aren't BOVs meant to prevent that from happening. Don't get me wrong, it sounds pretty cool, buuuuuut I bought it so fluttering didn't happen...
Old Nov 14, 2011 | 06:06 AM
Raptord's Avatar
There's your problem. Evo's are supposed to use DV's as with a VTA setup the engine loses air that was calculated by the MAF. There are supposed to be ways to tune around it but I'm not familiar with the process. Going back to recirc is your best bet IMO.
Old Nov 14, 2011 | 06:18 AM
CJ2X's Avatar
+1
Go back to stock or get a IX BOV.
Old Nov 14, 2011 | 06:30 AM
kyoo's Avatar
do the AFRs drop really low and the car feels like it almost forgot to stay on and then it gives itself more gas/revs to come back? I think it can be tuned out.
Old Nov 14, 2011 | 09:05 AM
escodotcarter's Avatar
I just got rid of my hks bov which was vta. Went with a stock IX bov and it was like night and day difference. Driveability has much improved.
Old Nov 14, 2011 | 09:17 AM
Murf's Avatar
Agree with above. Go back to a stock 9 DV . No real need to change it out unless you just want the sound. If that is what you want better options exist.
Old Nov 14, 2011 | 09:39 AM
Evoixjohn's Avatar
Recirculate kit! I just had to go pick up some radiator hoses that would fit good and also look nice for the set up.
Runs perfect hitting high boost with no issue!
Old Nov 14, 2011 | 09:50 AM
boostedtres's Avatar
Heres a good solution:
Step 1: Uninstall HKS BOV
Step 2: Take said valve and smash it into the ground as hard as you can. If that does not work, I always enjoy fire.
Step 3: Go stock 9 DV crushed or otherwise, APS or similar, or Tial/Speed Density.
Step 4: Re-think buying an evo, and if you decide your worthy, stop buying crappy part that give you crappy results which results in crappy questions.
Alternative: Instead of smashing you can find the sickest, lowest, wides wheeled jetta 1.8T and sell it to him for 1,000,000,000 dollars by telling him anyone whos anyone in the hellaflush scene has this....
gl with you fix
