Evo X intercooler piping question
Old Apr 27, 2010 | 05:58 PM
SOG RA's Avatar
Hey guys,
I have some pics here for you evolved membrs to look at. I am switching out to an evo x fmic and plan on using the stock evo piping. If you could look at these two pics and tell me what I would need to do that. I have numbered the parts in the attachment, so if you know what I would need just tell me the numbers. Thanks so much. Im pretty sure the metal pipe with the bracket welded on is the pipe running from bottom of BOV. Again, even if you arent sure about everything, but you know if one item is needed, please let me know, it would help out alot. Thanks
Attached Thumbnails Evo X intercooler piping question-parts.jpg   Evo X intercooler piping question-parts2.jpg
Old Apr 30, 2010 | 05:08 AM
Splatzjackson's Avatar
Haha this is like a puzzle.
1 - UICP - goes with #8 - attaches to FMIC
8 - UICP - goes with #1 -attaches to turbo outlet
7 - BOV pipe lower to LICP (this is the pipe I had to cut to fit)
The remaining pipes aren't familiar.
You are missing the rest of the LICP. If you don't want to change the LICP right now all you need is 1 & 7 and two more O-clamps. Please keep in mind that the stock RA sits shorter on the radiator so you will need to come up with a longer hose (and one more O-clamp) from the UICP to the stock RA FMIC or you will come up short.
Hope this helps!
Old Apr 30, 2010 | 07:37 AM
tjac357's Avatar
Why don't you just take the pipes off and replace them piece by piece? I just think that would be the easiest way.
Old Apr 30, 2010 | 08:10 PM
SOG RA's Avatar
Is this needed?
Old Apr 30, 2010 | 08:30 PM
Not for the IC swap that I am aware of.
Originally Posted by SOG RA
Is this needed?
Old Apr 30, 2010 | 10:44 PM
tjac357's Avatar
Is that some sort of boost controller? tiny pic btw
Old Apr 30, 2010 | 11:23 PM
Taranis's Avatar
It does look like the assembly where you put the boost pill.
-Taranis
Old May 1, 2010 | 07:14 AM
Kieffer87's Avatar
Just looks like the vacuum lines for the boost pill. Not needed for the piping swap but will be useful if you get a boost pill and want to change back and forth to the factory one easier.
Fizylftingdrnks
Jul 29, 2016 11:31 AM
alvar350z
Oct 25, 2012 04:40 PM
churbo
May 11, 2010 07:02 AM
Turbojunkie
49
Mar 19, 2006 09:02 AM
thestaton
Jan 10, 2005 08:33 PM
