AMS BOV, PSI release values
Old Jun 30, 2010 | 05:54 AM
h4ckluserr's Avatar
I grow tired of the BBV we have. It is to quiet for my flashy tastes
Does anyone have the PSI release values for their BOV? I know it won't make a difference if it's up or down by a few PSI.
I just want a simple looking BOV(AMS is kind of generic looking, where you look at the HKS SSQV and it has a very bold standoutish looking IMO)
any rate, I couldn't find a direct "talk about your BOV" thread. Do you have any preferences? I just want more noise out of it, without sacrificing quality branding.
*Sidebar* throwing on an AMS Test Pipe as well, not intending to tune yet, any thoughts?(Plenty of these threads, but figured I would combine it instead of spamming multiple threads)
Old Jun 30, 2010 | 06:16 AM
mikesim's Avatar
i have the turbo xs hybrid Type-H bypass valve. it recirculates so no CEL, and sounds decent too. you can adjust the spring by putting shims inside. it comes with 5 or 6 shims and i'm using 3. i notice a little flutter under light throttle, so i might take one shim out and see how it goes. most good bov's are adjustable like that. start with a tight setting and go until it doesn't flutter.
there are tons of sound clips on youtube for BOV's if you're looking for a certain sound. the turbo XS bov's are a standard PSSSSH sound.
no need to tune for a test pipe or downpipe apparantly, but you could probably gain a few more ponies with a dyno tune.
Old Jun 30, 2010 | 06:21 AM
h4ckluserr's Avatar
Hmm Yeah, just looking for something simple. a bolt-on, make more "look at me" noises, upgrade. Besides, having a decent BOV will help with power delivery anyways.
As far as the test pipe goes. I'm on about it, but I'm leery. With these TC-SST popping at 20k miles I'm afraid of doing anything that might point that back at me. Would give me an excuse to drop in an EVO X 6 speed.
Old Jun 30, 2010 | 06:29 AM
mikesim's Avatar
my dealership said a turbo back exhaust wont void my warranty. it's different for each dealership, but that's about all they let us put on the car here other than suspension mods.
Old Jun 30, 2010 | 06:53 AM
h4ckluserr's Avatar
Hmm... I'll have to call up my dealer.
Reading through some other posts I saw that AMS has a test pipe with O2 sensor mount on it that avoids the CEL?
Old Jun 30, 2010 | 06:58 AM
JaxRRevoX's Avatar
AMS doesn't make a BOV for your car or the X. And you should care about performance and not the way it "sounds" or the way it "looks" but thats JUST MY opinion....and if you are gonna run a TP i highly recommend you get it tuned very soon
Old Jun 30, 2010 | 07:20 AM
h4ckluserr's Avatar
Yeah, but I don't want to touch anything that's going to impact my warranty to bad.
but yeah, until that warranty runs out, minor cosmetic and aesthetic changes. Little things, tint the windows, plasti-dip the chrome, maybe paint the rims. I replaced the mitsu-star on my trunk with a chrome Decepticon emblem.. Subtle but it makes the car personal to me by tailoring the look to me. I know a TP won't affect it too much. it will open up the exhaust which will help a bit with revving and turbo feel. and a solid metal BOV will serve to help with Turbo spooling as well. but mostly I get the Generic "PSSHHHH" noise. This is my first turbo car that I've personally owned, and Damnit it needs to PSSSHHHHh when it shifts!
but on a serious note, I'm trying to deduce a way to avoid the CEL with a new BOV.
Old Jun 30, 2010 | 07:24 AM
initial_d2k's Avatar
I have the Greddy Type RS Recirculate (Evo 8) kit. The only other BOV i would go with would be Coto, Tomei, EvoX OEM or Synapse... (just my canadian 0.02)
With the Greddy, I get some low rpm flutter like at 1-2psi .. everything is alright after 5psi ..
I just installed the Defi Boost Gauge and feel 10x better when knowing the boost level is correct =)
Old Jun 30, 2010 | 07:26 AM
h4ckluserr's Avatar
Yeah, I know I need to go with a recirculate to avoid a CEL...
Is there a way to use a standard BOV and not get the light? regardless to brand?
Old Jun 30, 2010 | 07:39 AM
meat_EVO's Avatar
running a testpipe without a tune on a X is fine. youll pick up like 7 whp and shes still running in the 9 afr's.
now with the BOV. I wanted something that performed and would not leak. but i didnt want to spend a whole heck of alot of loot and i hated the stock location.
I like the HKS quality, but hate the sound. But it never leaks.
So i found a hks, new on ebay in teh stealth black for like 130 shipped. and bought a pre flanged cast pipe to fit it for 12 bucks new. also on ebay. I then modified my stock LICP to make it all fit.
in order to get rid of teh horrid noise the HKS makes, I simply removed the Plastic 3 point piece in the end and now my HKS sounds like a tial.
Old Jun 30, 2010 | 07:44 AM
h4ckluserr's Avatar
Very nice, the minor HP gains from the TP are about what I expected. forgive my ignorance "afr's"?
Did you have any issues with CEL putting on a standard BOV? that's my biggest concern.
Old Jun 30, 2010 | 07:49 AM
meat_EVO's Avatar
afr= air fuel ratio. Very important.
the CELs cam be turned off using ecuflash. its honestly a easy task, but, yes, any aftermarket BOV will probably give you a cell.
Old Jun 30, 2010 | 07:59 AM
h4ckluserr's Avatar
that was it.. duh on my part.
I was racking my brain for some method I was unaware to avoid a CEL.
Oh well, time to find a BBV that will do what I need, while not tripping the CEL
Old Jun 30, 2010 | 07:35 PM
SOG RA's Avatar
Look into the synapse bovs. I have heard good things about them. Granted you would want to set it up for recirc, maybe that would give you what you are looking for. As far as the AMS bpv, its the Evo x bpv. I have one on my car. I am going to selling it soon, if you are interested still.
Old Jul 1, 2010 | 08:05 AM
h4ckluserr's Avatar
As mentioned this is the first turbo car I've owned so I dont' know to much about the finer nuances off the setup.
You said it would need to be set up for recirc... can any BOV do that?
DontStopMe
Feb 25, 2017 12:32 PM
dvd_mi
16
Nov 19, 2009 05:27 PM
StevenStarke
20
Jun 13, 2008 12:32 PM
bvdawg13
13
Apr 19, 2007 11:07 AM
EVO8LTW
14
Mar 11, 2005 08:17 AM
