ultimate racing intake with cobb stage 1
Old Sep 15, 2010 | 09:17 PM
robyn402's Avatar
trying to figure out if its ok to run this intake without getting my car re-tuned... i was thinking i wouldn't because its using the factory MAF from what i can see...
i'm running the stage 1 93oct map, found the intake for cheap for like 50 bucks so figure why not but wanna check to see if anyone has any experience with this combo before i go wasting any money...
or if someone can give me some advice on adjusting my tune since i have accesstuner race, but i never ventured into tuning
Old Sep 15, 2010 | 09:22 PM
Rocky_RA's Avatar
I wouldn't put the intake without being tuned for it, you don't want to run in some problems with your car.
Old Sep 15, 2010 | 09:44 PM
Gman4ver's Avatar
yes need to get a Tune with a intake, i wouldnt take the chance. I would still buy it for $50, just wait til you get the part you want and tune it with them all......
Old Sep 16, 2010 | 05:16 AM
zx-319's Avatar
If you are using the factory MAF housing, you MAF sensor should read the increased air flow and adjust the gaz mixture accordingly.
If you have access to a Wideband sensor, I'd recommend looking at your AFR. At idle is should oscillate between low 14 and may sometime go close to 15 (like 14.9). If you see it above 15, remove it put back your stock one and go get a tune.
If it's in safe range on idle, try to do a run. It should never go above 14.7 when you're below 3000RPM and when you go above, you should first look at your Fuel injection map to see what is the target AFR. And use common sense to see if you actually run lean or if you're safe.
If you want to venture tuning your car, you should really be using a wideband sensor and I'd recommend a few other gauges (boost gauge, Oil Pressure/Temperature). Always do minor changes and monitor their effects. If you go too fast you increase your chances of doing something stupid and blow your engine
Look in the EVO X Engine Management section to get some better knowledge about how to tune and what is safe for our engine.
Old Sep 16, 2010 | 05:58 AM
robyn402's Avatar
thanks for the info, i'm actually just about to get a bung in my oem DP so i can use my wideband... i'll get back to you guys with the results
DarwinX
17
Aug 30, 2015 09:09 PM
SeanM505
Cobb AccessPORT
17
Apr 8, 2013 08:22 AM
tscompusa2
Nov 15, 2010 12:33 PM
hameedosh
18
Jul 3, 2009 01:31 PM
groove304
40
Oct 31, 2008 11:20 AM
