Blowing Off Twice
Blowing Off Twice
It is normal to have the blow off value blow off twice when getting off the throttle aound the time the transmission shifts into the next gear? It seems it blows off in the first gear and then it shifts into the next gear and blows off again. I have a hks ssqv blow off value on it and its vented.
Curious how you managed to install an aftermarket bov and not know what it does?
By the way, it's fine. It's suppose to blow off when you release the pedal
I didnt install the bov I bought the car with it on it already on it, but I have installed them before on other cars. I know its supposed to blow off when u get off the throttle but my question is it seems to blow off twice when its about to shift when I get off the throttle. I was thinking it was doing this because it was inbetween gears in the sst transmission and blows off once in the one gear shifts and blows off again in the next. I was just curious if it was normal.
Im not letting off the throttle to shift. Im just talking about when I happen to let off the throttle when it shifts.
That makes the most sense to me from what it sounds like when it does it.
yes lol if you gas it then let off the throttle all that built up pressure has to go somewhere and it vents the air out, so lets say you are going thru the gears and you just switched 4th to 5th and it blew off in between then you stop throttling and let off the pedal all together it has to do something with all the pressure you have built so you will hear it vent again. But again you should not be venting whatsoever anyways in a ralliart as it is a full recirculation car and the ecu does not understand that it has lost air when you vent
No and no. That's a stutter, hop on YouTube look up Synapse bov. They explain what causes it etc. If I remember correctly its due to a piston type bov that's spring needs adjustment. It is something you want to fix.
Yeah Im pretty sure its not that probably it runs great doesnt lose rpm when lifted, stubbles or stalls.
bml1024
Feb 6, 2017 11:34 AM
_Ryan_
Dec 19, 2014 01:54 PM
NASSER400+
16
Nov 23, 2013 04:59 PM
