Omegis RA to Evo X swap progress
Old Jan 6, 2012 | 08:07 PM
  #76
El-Diablo's Avatar
SST Transmission leaks
Last time i had a service they told me there was a dealer notice for cracks in the filter mount that are inspected and replaced at service.
Old Jan 12, 2012 | 01:14 PM
  #77
omegis's Avatar
Got my car back from the dealer today with a new transmission, new SST fluid, and a new SST filter for free. Back to fine tuning the EBCS.
As far as ECU info goes, as previously mentioned, the two pieces of data looked at for warranty claims are the CVN and Cal ID. When you flash your car to stock for warranty work, these two alphanumeric strings will pass as stock, appearing as though the ECU has never been flashed. Now I know there is talk about a flash counter but in my case, that wasn't factored into collected data for warranty work, only the CVN and Cal ID were documented.
Also, when the new transmission and TCU were installed, the car put out a "Service Transmission" code. From what I understood when talking to the tech, he had to reconnect the old TCU to clear the code, download the data from the old TCU (VIN association, etc.), and push that data to new TCU. Apparently the connector for the RA has 6-pins and the one for the Evo X has 20-pins. Sounded to me like there is some form of TCU communication available because I don't believe he was referring to the ECU. Just food for thought.
Old Jan 12, 2012 | 01:25 PM
  #78
sstevojr's Avatar
That sounds right, new transmission needs to matched to the engines VIN/ECU. Glad it all worked out, now on to more powa!!!
I was talking with a friend of mine who has BMW, and he was telling me that it's $500 to replace the battery because they also have a small chip inside that needs to be mated to the ECU. $500 for a battery, I hate BMW's more and more each day...
Old Jan 13, 2012 | 06:51 AM
  #79
omegis's Avatar
Still working out the tune. Cleanest run so far.
Old Jan 13, 2012 | 10:54 AM
  #80
RazorLab's Avatar
Need to work on that boost curve for sure...
Old Jan 13, 2012 | 11:02 AM
  #81
omegis's Avatar
Yep, just got version 4 of the tune minutes ago so we're still fine tuning the Grimmspeed.
Old Jan 13, 2012 | 01:51 PM
  #82
omegis's Avatar
Version 4
Old Jan 15, 2012 | 01:25 PM
  #83
pbassist12's Avatar
Good numbers, is this from the virtual dyno?
Old Jan 15, 2012 | 01:46 PM
  #84
sstevojr's Avatar
Post a VD w/ smoothing of 3, much better view of what needs fine tuning.
Old Jan 15, 2012 | 02:08 PM
  #85
Jechttt's Avatar
Look at that steady curve!
Old Jan 15, 2012 | 03:23 PM
  #86
omegis's Avatar
@pbassist: Yes
@sstevojr:
Old Jan 15, 2012 | 06:23 PM
  #87
sstevojr's Avatar
Lookin' pretty good so far! What's your timing at peak torque & red-line?
Old Jan 15, 2012 | 06:29 PM
  #88
RazorLab's Avatar
I'd be really careful with 13afr at 27psi
Old Jan 15, 2012 | 07:11 PM
  #89
omegis's Avatar
Old Jan 15, 2012 | 07:14 PM
  #90
omegis's Avatar
Yep, looks like boost is beating the drop in AFR but no knock so far.
