Omegis RA to Evo X swap progress
Old Jan 23, 2012 | 05:18 PM
  #106
omegis's Avatar
Originally Posted by Snipingdude
Hey Omegis..sorry for another ? lol, but you bought your turbo used correct? Did it have "some" shaft play? Im looking at some used turbos and prettym uch all of them have "some" "minimal" shaft play not hitting the turbine...now i know this is normal for the turbo as long as there is no IN/OUT play it should be good, just curious if your had "some" at all
The "used" one I purchased had less than 1k miles if I remember correctly. Almost no shaft play.
You are correct that you want NO in/out play and as little up/down as possible.
If you can move the shaft enough on your own to make the compressor wheel scrape the housing, your turbo needs rebuilt / replaced.
Old Jan 24, 2012 | 05:44 PM
  #107
omegis's Avatar
Anyone post-X swap have issues with the 2 bolts from exhaust manifold to turbo backing out? Found that's where the sound was coming from. Washers are installed and gasket is still good but bolts won't stop backing out after driving the car for longer than an hour. Using stock X manifold.
Old Jan 24, 2012 | 09:56 PM
  #108
AWDralliart09's Avatar
Hey just want to say thanks for sharing all the good info. Planning my X swap soon. Going the FP green rout as soon as the turbo gets in. Also I spoke with English racing today and they are going to help with my tune, because they are about 40 miles ways in Washington.. Did buy an Etune from them?? Just curious as to how you got your tune?
Old Jan 25, 2012 | 12:44 AM
  #109
omegis's Avatar
Good to hear!
Aaron @ English Racing provided me with my etune. Took a few revisions to get it perfect. He was very helpful and quick at fine tuning everything.
Old Jan 25, 2012 | 10:57 AM
  #110
Snipingdude's Avatar
Hey omegis sorry to ask another question ...but i guess its a general question, did you drain your oil and coolant before doing your swap? Im only asking because im curious of whether any if how much comes out of thel ines when your remove them from the engine and turbo...just picked up a turbo for 350 so im on my way there
Old Jan 25, 2012 | 11:12 AM
  #111
omegis's Avatar
Expect to replace coolant and oil.
Old Jan 25, 2012 | 11:49 AM
  #112
RazorLab's Avatar
You can pinch off the coolant lines no problem. Just make sure you don't compromise the lines doing it. Then just top off the coolant after install
Oil you should drain and then refill after the install.
Old Feb 3, 2012 | 12:00 AM
  #113
omegis's Avatar
This works too^
I wasn't so lucky and didn't think of pinching coolant lines but this was my first turbo swap so I accepted the learning experience. Also, the Garrett Evo X instructions told me to drain coolant but then again, I opted out of following Step #65:
"... Install Garrett stickers as necessary to increase horsepower output (2 bolts, 10mm socket, plastic clips, Garrett stickers)."
Old Feb 3, 2012 | 12:18 PM
  #114
masafina's Avatar
still snow in there?
Old Feb 9, 2012 | 03:06 PM
  #115
omegis's Avatar
Ordered the Summit Racing $100 battery relocation kit. Want the stock X air box in the car and later, the AEM intake. Got bored with the "whoosh" and heatsoak from the K&N SRI.
http://www.summitracing.com/parts/SUM-G1200A/
Old Feb 25, 2012 | 02:47 PM
  #116
omegis's Avatar
Battery relocation to the trunk complete. Wasn't that difficult. Out with the SRI, in with the stock X airbox. Ordered an AEM intake for the X and I'll install that when it arrives.
Old Feb 25, 2012 | 04:55 PM
  #117
silthos's Avatar
Looks good. Might have to follow and relocate the battery.
Old Feb 27, 2012 | 07:56 AM
  #118
omegis's Avatar
My radar detector can read battery voltage and it typically reads around 14v before and after cranking the car up. Since doing the battery relocation, it reads in the 11s before cranking and then 14v after cranking. Also, maybe it's because I didn't notice it before but the headlights momentarily dim (1~ secs) when the fan kicks on. I'm thinking it's there's voltage drop since there's more wire distance to cover.
Anyone, feel free to comment if this is normal or irregular for relocating the battery. I'd hate to kill my alternator. I've added the link to the kit I used in my above post.
Old Feb 29, 2012 | 07:32 PM
  #119
omegis's Avatar
AEM intake installed
MAF scaled 10%
Old Mar 1, 2012 | 09:15 PM
  #120
cstrainsgun's Avatar
Looking great! Just got my x turbo with 2k on it, coolant and oil lines, and stock manifold. Hoping to have everything else soon. One question, trying to decide on a aftermarket (AMS or UR) O2 DP or just stick with the stock o2 housing and re use my UR short DP. Are the AMS or UR ones worth the cost? Anyone use them on their swap?
