Strange Engine Noise.. need some help diagnosing
I am having that same noise from the engine of my 2011 MR with only 3200 miles . However, it sounds like it is coming from the left side of the engine close to the throttle body ( in that general area).
I would like to know also if this is normal, noticed it a few days.
Please keep me informed.
I think we could have ourselves much shorter threads if we instead decide on the following subjects:
I have an RA/Evo that makes no weird engines noise at all - is this normal?
or
Post your 4B11 engine failures that occurred as a direct result of you ignoring one of its thirty-three rattling noises
When cold or just driven lightly around town, my car sounds like it has one of more of the following:
Jah E, if you're still under 4000 miles in your MR, the best way to allay your concerns is simply to discuss with your dealer/service center at its next posted maint dropoff. Unless you've modded the $#*!!# out of it already!
They'll listen to it, undoubtedly tell you it's normal, and you'll have peace of mind.
Rich
or
- The wrong oil in the engine.
- No oil in the engine.
- No oil in the diffs.
- Manually adjusted tappets in dire need of adjustment.
- Tappets from a tractor engine.
- An old Kingswood clutch (that one's for the aussies).
Rich
razorlab
5165
Aug 11, 2024 07:56 PM
vaqusis
56
Sep 29, 2017 08:35 AM
razorlab
38
Aug 31, 2017 09:20 AM
