2010 RA Differential fluid change
Old May 15, 2011 | 10:15 AM
SPSERG's Avatar
Afternoon all,
A little background first... I have a 2010 RA I bought brand spanking new last April. It has 9270 miles, and I garage it over the winter by choice. I have been absolutely meticulous about maintenance, and run synthetic motor oil changing it every 3K or less. I have been watching some threads about changing fluids and decided I would start with the rear diff this weekend- easy enough and I can do it in short order.
Warmed up the car, pulled it into the garage and got started. Factory fluid that came out was still pretty clean, but the drain plug looked like it needed a shave! Got all the metal fragments off the magnet, but was surprised how much caking there was at the magnet base. Have you ever seen the caking under old valve covers? That was it.
When the last bit of fluid were draining out, I saw some blockage in the drain hole. Luckily, I bought 2 qts of Mobil 1 gear oil so I flushed them out with fresh fluid. I refilled the diff, ran around the block and drained it again- no more foreign objects just clean fluid. And yes, filled it to factory levels.
I am attaching the pic of this debris. It has some fibers to it, thinking this may be loose clutch material from the pack's that congealed together with sludge at the diff's bottom. It is not solid, and turns into paste and smears if you squeeze it- not like gasket material either.Strikes me as odd, since the car has so little mileage and I baby it when I'm driving.
Anyone run into similar debris when working on their differential? This makes me REALLY want to do the front, and spend the money to change the SST tranny fluid and filter as well.
Old May 15, 2011 | 12:20 PM
RazorLab's Avatar
Yes it's totally normal to have that debris on the drain plug when you do your first change.
Old May 15, 2011 | 01:47 PM
SPSERG's Avatar
Debris picture
Not sure what happened to my pic, it was there... Thanks for the reply, I honestly expected to have some material on the drain plug. All the components are new and they are still wearing together, its the clumps that concerned me.
Old May 15, 2011 | 01:50 PM
SPSERG's Avatar
Old May 15, 2011 | 03:56 PM
03chi-town0Z's Avatar
Yeah, it's a bit unnerving if you're not ready for it. Looks like metal shrapnel until you squeeze it and it melts between your fingers
Old May 16, 2011 | 04:15 AM
SPSERG's Avatar
Fragments
Thats exactley what it did... The clumps would smear between your fingers. I have been on the fence about taking the money and time to change the SST fluid and filter at 9K, but after this I ordered the parts last night!
Old May 16, 2011 | 11:45 AM
sstevojr's Avatar
Just had mine done on Friday, same thing, the plug was CAKED! At first they thought something was wrong, but it just rubbed away, no solid pieces, and its all good
Old Nov 12, 2011 | 06:53 PM
TheNEWB's Avatar
pics of the drain and fill holes on the RalliArt?
Old Nov 13, 2011 | 06:22 AM
08Lancer89's Avatar
Pictures are not showing up
Old Nov 13, 2011 | 10:33 AM
sstevojr's Avatar
https://www.evolutionm.net/forums/ev...ld-change.html
3-seconds with the Search button
Old Nov 20, 2011 | 11:23 PM
TheNEWB's Avatar
Originally Posted by sstevojr
Thanks for the info. Except that is a picture of an EVO Rear diff. I was specifically looking for a picture of a Ralliart rear diff.
Old Dec 15, 2011 | 12:48 PM
Skyline Fever's Avatar
I knew the OE fluid was going to be terrible looking at 10,000 miles, so I changed the OE fluid with conventional Valvoline 80w90 gear oil.
I will put in full synthetic in next. I'm more interested in getting rid of most of the deposits before I fill it with synthetic gear oil.
Seeing that also motivated me to learn how to replace the fluid in the TC:SST
Old Jan 27, 2014 | 06:56 PM
pepsi_merch's Avatar
its hard finding stuff for the RA and not the Evo, i almost got real confused when i saw this pic:
chaotichoax
32
Feb 11, 2020 09:00 PM
Evoivnz
Oct 7, 2015 12:44 PM
rupp003
May 14, 2014 09:44 AM
WhosEVO
Apr 13, 2004 11:03 AM
runny_yolk
Apr 12, 2004 08:09 PM
