AMS intercooler
Old May 16, 2011 | 03:16 AM
El-Diablo's Avatar
AMS intercooler
ANy difference between the AMS EVO X and ralliart intercoolers? Pics on their site show a bend in one of the mounts.
Anyone used mishimoto?
Old May 16, 2011 | 01:18 PM
ETS Michael's Avatar
I wouldn't use the Mishimoto if you have the choice.
Old May 16, 2011 | 02:02 PM
SudzRA's Avatar
The bend on the left side (looking at the front of the intercooler) allows the mounts to be even, since the mounting point on the left side is lower than the mounting point on the right side. The fitment is perfect with the bend.
I just installed mine a couple days ago, check this thread:
https://www.evolutionm.net/forums/09...tercooler.html
Old May 16, 2011 | 03:55 PM
Andrew@AMS's Avatar
Perfect explanation
BTW The intercooler looks great!
Old May 16, 2011 | 04:14 PM
10Sportback's Avatar
So other than the bend they are identical?
Old May 16, 2011 | 06:30 PM
Jay10Ralliart's Avatar
FCOTM Winner
the fitment is perfect....it literally took me ten minutes to install with no problems.
Old May 17, 2011 | 10:19 AM
SudzRA's Avatar
Originally Posted by Andrew@AMS
Perfect explanation
Thanks Andrew!
The intercoolers are far from identical. The AMS is much taller, therefore it requires you to run an Evo X type UICP. It's also at least an inch thicker. With the right UICP, however, it fits like a glove. In the thread I posted above you can see me holding both intercoolers for comparison.
Old May 17, 2011 | 10:35 AM
This is correct.. The upper pipe is required to install the intecooler on the RA. The lower connection is fine.
Here is a picture from a thread I did a while back.
this shows the size difference between the two as well as inlet and outlet placement.
We have had several customers do the install now and the upper pipe is a must. The RA also has a ridiculous factory upper pipe which balloons up under throttle... It's worth the upgrade.
Good Luck!
Michael
Old May 17, 2011 | 05:25 PM
But the AMS for Ralliart and AMS for Evo X are they identical other than the hanger on the passenger side?
Old May 18, 2011 | 08:22 AM
SudzRA's Avatar
After looking at pics, looks like this is correct.
NinjaX
Apr 16, 2017 10:41 AM
its2ply
Apr 28, 2015 03:25 AM
Aznstylistic
Aug 21, 2012 05:01 PM
JdmEvo's
Jan 14, 2010 07:06 AM
Jcusco407
Sep 16, 2009 04:20 PM
