Cel p2253, p0132, p0134
Old May 20, 2011 | 12:28 PM
lookmanohands's Avatar
So I was on my way home from work when the CEL popped up. Got home and used my Access Port tuner to read the code. It was a P2253 and it had no description.
The next day I started her up and within a few seconds the idle sounded odd. Kinda sputtery. I used the AP tuner and found that 2 other codes popped up along with the P2253. It was a P0134 - heated o2 sensor circuit no activity detected (sensor 1) and a P0132 - heated o2 sensor circuit high voltage (sensor 1).
I took a video of the car starting, the sputtering starts at about the 20 second mark.
So far this has only happened when the engine is cold. When the car is warmed up the sputtering goes away. My car usually sputters when at cold idle but never this bad...
http://www.youtube.com/watch?v=XnUdRDutrpw
Let me know what you guys think it may be.
I know there is a thread about a P2253 but I did not want to thread jack, seems like he is having a different issue.
Old May 23, 2011 | 08:29 AM
No one?
Well I ended up getting under the car and removing the o2 censor. Checked to see it there was anything odd and re installed it. So far its been ok, no heavy sputtering on cold start and no CEL.
I guess it could just be a loose cable. When the Ultimate racing exhaust was put in the cable protection needed to be peeled back and the 3 wires exposed and routed over the exhaust.
Any feedback would be appreciated.
Old May 24, 2011 | 09:32 AM
bossssman38's Avatar
What part of the exhaust did you need to feed the wires over? I'm getting the high flow cat and midpipe soon, just want to know what I'm getting into. Also, how is the sound with the resonator? I'm trying to decide between the mini-muffler and the resonator. Where on LI you at?
Old May 25, 2011 | 08:18 PM
The exhaust was actually installed by no limit motorsports and they routed the cable over the exhaust and around a hanger so it doesn't touch the exhaust. With the resonator it sounds sooo sexy. Its perfect blend of growly and loud. I get so many compliments on it. I live in Port Jefferson Station on LI. Where u at?
Old Sep 18, 2011 | 02:49 PM
mitsael's Avatar
Did you ever figured out what was the problem ????
Old Sep 18, 2011 | 09:08 PM
baggelis's Avatar
i ve been getting the p2253 code it comes and goes all the time i was assuming that thats because im running a catless testpipe but i guess not
Old Sep 19, 2011 | 10:37 AM
mitsael's Avatar
I being running cat less for a while already and never had that code pop at all.
Old Sep 21, 2011 | 05:41 AM
p1llar's Avatar
With your AP are you able to clear codes yourself? If you get a CEL from a Catless test pipe, can you just remove cel permantely by using the AP?
Old Sep 21, 2011 | 11:50 PM
baggelis's Avatar
if you find a solution on how to get rid of the p2253 code let me know
deanob
Cobb AccessPORT
May 9, 2023 11:04 PM
Mweisel
Feb 23, 2018 02:08 PM
LSs1Power
Cobb AccessPORT
Jul 11, 2017 07:45 AM
BlackHawk_Tsi
Apr 17, 2015 05:39 AM
BadazzCR
Aug 23, 2008 07:40 AM
