RA rear diff ratio and pic request
Old Sep 1, 2011 | 12:58 PM
RazorLab's Avatar
You guys know that 4.062 "final drive" number is not the rear diff ratio right?
Originally Posted by zx-319
And now that I think about the transmission, I think the 5spd and the SST both have the front AYC built-in, so there has to be some logic in the ECU to manage that... But I am not familiar at all with this part.
If I were you, I would stick with a 5spd from the EVO (if the AYC thing is not a problem) and the Ralliart rear-end... Since you probably have to get a custom drive-shaft anyway, you don't really car about the input shaft of the rear-diff... As a matter of fact you could take ANY rear-end that physically fit there...
AYC is the rear diff on the GSR/MR
ACD is the front, in the transfer case. ACD and AYC share a seperate control unit (DCU) then the engine (ECU)
Old Sep 1, 2011 | 01:06 PM
Alchem1st's Avatar
Well, I suppose the final drive is the important part of this correct? I'm not super great with my terminology so you'll have to pardon me, but the final drive should be how many turns it takes to the rear diff input shaft to make the rear wheels make a revolution or something like that. So if the front and rear are different, then either the front or rear set of wheels will turn faster and cause your drivetrain to lock up. (or you'll always be doing burnouts ) How is that different from the diff ratio? Also, I knew AYC was rear diff only on the 1-9, but I wasn't sure about the X. I'd rather know about what I'm talking about before I say anything haha. Thanks though.
Old Sep 1, 2011 | 01:17 PM
zx-319's Avatar
Personnally, no... I just assumed that the person who brought up this info knew what he was talking about. I know my Firebird has a 3.23 and I want a 3.73.
I thought both the front and the rear shaft had a AYC. Just a question like that, do you think the AYC from the EVO would be a direct fit to replace the rear-diff of the ralliart? The logic to control a AYC should not be too complicated to reproduce using an external microcontroller with a CAN Bus and an ADC...
Old Sep 1, 2011 | 01:26 PM
RazorLab's Avatar
AYC is *only* on the Evo 10 GSR and MR in the USA.
No Evo's in the USA had AYC before this.
AYC is only on the rear, it is a totally different rear diff unit then the non AYC rear diff. AYC torque vectors between left / right rear wheels.
ACD is the center diff and located in the transfer case. This is on USA models, 2005 Evo 8 to 2006 Evo 9. 2008-2011 Evo 10's and 2009-2011 Lancer RA's.
Both AYC and ACD are hydraulic clutch pack type units. Controlled by the ACD/AYC ECU (seperate then the Engine ECU) and actuated by the hydraulic system.
Old Sep 1, 2011 | 01:40 PM
Alchem1st's Avatar
I understand this, I'm not just talking about US models. I have a JDM Evo 4 rear end with all the AYC bits for sale because I don't want to mess with all the wiring. AYC isn't just the AYC ECU and the diff, it has many sensors all over the vehicle that I don't want to mess with tracking down, purchasing, importing, and if everything goes well with that then wiring all that crap in when I can just use an 8 diff in it's place. I imagine that anyone who would want to convert their Lancer to AWD or their RA to the X transmission wouldn't want to mess with finding all those parts and wiring it in either. I know what I'm talking about as far as the parts and systems go. If I didn't, I wouldn't have started this thread in the first place. You didn't answer my question by the way what's the difference between the final drive and diff ratio? I believe they're the same thing. At the very least, I didn't realize that the RA had the ACD, so that's good info for me as well.
Old Sep 1, 2011 | 01:52 PM
zx-319's Avatar
No details about what all those sensors are? Are you sure they are not related to traction control rather than AYC?
I mean, a basic implementation of a AYC would just take into account steering position... A slightly more advanced should take into account the rotating speed of each of the 2 wheels to get some feedback and actively adjust clutch pressure...
Old Sep 1, 2011 | 02:11 PM
Alchem1st's Avatar
It uses alot of different types of sensors. ABS sensors (which you already have), and some special sensors that can detect when you car isn't moving in the direction that the wheels are pointing. (drift) AYC is much more advanced than just adjusting the car using steering wheel position, though that is part of it. (2 sensors in the steering wheel on the Evo 4 I believe) I have the complete Evo 4 AYC wiring diagram somewhere, but I'd have to look for it. AYC has gotten even more complex since then though with the development of the S-AYC system.
Old Sep 1, 2011 | 02:39 PM
RazorLab's Avatar
Listen, I'm not challenging anybody here. I'm relaying information.
Final Drive Ratio:
The final drive ratio determines how many revolutions your engine must develop for each rotation of the wheels. It depends on the drive ratio of your transmission, the number of teeth on the pinion gear in your differential and the number of teeth on the spur gear in your differential. It can be calculated with a bit of information from your owner's manual and your dealer, and some simple multiplication and division.
Read more: How to Calculate Final Drive Ratio | eHow.com http://www.ehow.com/how_5183425_calc...#ixzz1WjtDzBoj
ACD and AYC use input from sensors located in various places. Example being brake sensors, wheel speed sensors, G-sensors, Steering wheel sensor, etc etc.
If the car has ACD then it already has these sensors.
Old Sep 1, 2011 | 03:08 PM
Alchem1st's Avatar
Final Drive Ratio:
You're alright. I just don't like my knowledge of Mitsu's AWD systems being doubted as I've put alot of research into it. I realized you meant no offense, I was just stating that I know what I'm talking about when it comes to the subject (for the most part ) and if not, then I won't say something without researching it first. Still though, I don't see how the final drive and diff ratio are different, I think it's just different ways of saying the same thing. Interesting about already having the sensors as well. Are all of the needed AYC sensors there then or do we know for sure?
Ganabi
Nov 12, 2023 11:30 AM
honda-guy
13
Sep 18, 2018 08:50 PM
JdmEvo's
May 5, 2016 08:12 AM
2DCVIN
Apr 4, 2016 09:38 PM
foxbat
Mar 6, 2013 07:59 AM
