2010 RA - Cel P00117 Code
Old Jan 9, 2012 | 03:36 PM
robearralliart's Avatar
2010 RA Sportback
I got a P0017 code when the SES light went on about 2 weeks ago.
I have Chain Stretch issue at 9,000 miles, which the dealership fixed.
I now have 17,000 miles on the car.
It started stumbling in idle, and rpm, and the tranny was shifting really high RPM, then dropping really low.
Dealership has replaced the following:
crank/camshaft position sensor
Oil Control Valve
Timing Chain
Re-downloaded ECM & TCM program
Still throws a code right at start up.
They have had it almost 2 weeks. The dealership cannot diagnose the problem, and have no answer for me as of today.
It is still under warranty, that is why I took it to the dealer.
No upgrades, ever, not even a k&n.
Can any of the EVO & RA gurus here help me? Any ideas?
Old Jan 10, 2012 | 03:35 PM
Update:
Got it back today.
Cause: Found Code P0017
Engine Oil Control Valve (Exhaust) - Replace
Sensor - Camshaft Position
Valve, Oil Feeder Control
Per TSB 11/13/2008 Tech Reprogrammed ECM. After Re-prrgram & Test drove, code P0017 reset. Replaced Exhaust Side Cam Sensor. After cam sensor, code reset.Inspected timing chain, found good. Replaced Exhaust Oil Control Valve & Re-programmed, Drove 85 miles, No Code found.
I hope that I am done with this issue. I am scared to do anything to the car, as I would have to strip it down everytime I take it to the dealer.
But, I hope these few posts anybody else having the same issue.
Old Jan 10, 2012 | 03:48 PM
TOralliart's Avatar
See if you qualify for the Lemon Law. You seem to be having A LOT of issues.
Mcfixit
Lancer How Tos / Installations
Feb 4, 2015 12:10 AM
leo_99
Feb 25, 2013 08:20 AM
Dynotech Tuning
May 20, 2011 08:27 PM
desperado-c
Mitsubishi TC-SST Discussion
18
Aug 11, 2008 09:48 AM
