ACD fluid drain plug
Old Jan 11, 2012 | 04:36 PM
Skyline Fever's Avatar
Where is the ACD fluid drain plug for a 2010 Lancer Ralliart Sportback? I would like to drain it out and replace it with Amsoil.
Old Jan 11, 2012 | 04:51 PM
jkennedy293's Avatar
The drain plug is located on the bottom of the ACD, which is near the engine oil pan. It is a 24mm nut.
Old Jan 11, 2012 | 07:06 PM
Thanks!
Old Jan 18, 2012 | 06:24 AM
andrewzaragoza's Avatar
Are you talking about the transfer case or the acd pump oil?
Old Jan 18, 2012 | 11:50 AM
RazorLab's Avatar
Exactly, two totally different things.
Old Jan 18, 2012 | 04:12 PM
ACD pump oil is what I want to change. I want to use Amsoil ATF there.
I already replaced the transfer case oil. I used Valvoline 80w90 GL5.
Old Jan 18, 2012 | 05:58 PM
Why? The fluid is only used to apply pressure. Its not used for lubrication.
Old Jan 19, 2012 | 04:50 PM
Some posts have indicated that when the car is used in extreme cold, the ACD pump dies quickly, and ATF with better cold flow properties might prevent that.
That is why I will replace it.
Old Jan 19, 2012 | 05:58 PM
It only affected vehicles subjected to sub-freezing temps. You live in Florida. Doesn't make sense to go through the hassle to replace the fluid.
That being said, its your time and money. Have at it bro.
Old Jan 20, 2012 | 05:23 AM
Veronica's Avatar
^ x2. Spend the mod money on something that will make a difference.
Old Jan 20, 2012 | 09:42 AM
you will have to bleed it. not sure if evoscan can actuate it.
Old Jan 25, 2012 | 06:04 AM
cyrusthevirus's Avatar
i need to replace my ACD fluid in my 06 mr? can i get any amsoil ATF fluid?
im changing the clutch out thats why
Old May 23, 2012 | 09:02 AM
I was finally able to replace the ACD fluid with Amsoil.
What I did was remove the reservoir cap and loosen the bleeder screw. I used my mityvac vacuum pump on the bleeder screw, and after that, the fluid gravity bled. As long as the bleeder screw was wide open, I could gravity bleed the ACD.
The method where you turn the key on but don't start the engine, then hit the gas pedal did not work for me.
Hopefully I will get good life from the ACD pump.
Old Jun 11, 2012 | 07:35 AM
Rahtid's Avatar
You might want to drain that Gl5 and put diaqueen back in for the transfer case
05-EVO-GSR
Jun 17, 2015 08:26 PM
Gsr08
Jan 8, 2014 06:56 PM
sandman43103
37
Jan 16, 2009 11:12 AM
ZeroFighter83
Jun 12, 2008 02:17 PM
JT-KGY
Nov 23, 2003 09:24 PM
