Fp Red Dyno Results
Old Nov 1, 2014 | 07:19 AM
  #136
spider21's Avatar
Originally Posted by silthos
I was still on stock clutches. Kozmic started pulling the transmission today. All I can say is that my tune is on point. Only 20 hp difference between vd and the dj I was on.
The clutches you will enjoy!! You will notice a major difference after they are installed. I will guess you will have a retune done by Kozmic to take advantage of the holding power you will have will love to see the Dyno. Again the 255 is small for the power you have must have some freak pump :-).
Old Nov 1, 2014 | 11:51 AM
  #137
silthos's Avatar
Yeah I figured since it's there I'll have them tune it. Can't wait to see how the new clutches perform. Hopefully I'll be able to use launch control now. Maybe kozmic will video my dyno for me as I'm 4 hours away from the shop. As far the pump, I was told it was good for my power goals at the time so I don't know lol.
Old Nov 4, 2014 | 06:25 PM
  #138
silthos's Avatar
My Ra in the background lol
Old Nov 5, 2014 | 04:21 AM
  #139
spider21's Avatar
E-85 tune completed!
I have a question why does your dyno say gear 3 when it should be gear 4. So 420hp 350tq on a mustang dyno than vs a dyno jet? Just wanted to compare number. You have to be running out of fuel even at those levels.
Old Nov 5, 2014 | 08:06 AM
  #140
silthos's Avatar
I don't know why that says 3rd gear because all the other ones have been in 4th gear.
Old Nov 6, 2014 | 12:40 PM
  #141
spider21's Avatar
I just know number would be completely different in 4th is why I asked
Old Nov 9, 2014 | 07:40 PM
  #142
spider21's Avatar
Also Where is Kozmic's Dyno Graph after the clutch install. Evoscan is a VD Dyno...
Old Nov 10, 2014 | 09:56 AM
  #143
silthos's Avatar
No dyno graphs yet. Transmission just came out the car. All those dyno graphs were prior to bringing my car to Kozmic.
Old Nov 19, 2014 | 09:30 AM
  #144
silthos's Avatar
Update: Transmission needs some TLC. Upgrading clutches like planned but also have to replace some seals and I need a new torque damper assembly. Also decided to upgrade turbo to an ETS T3 setup.
Old Jan 3, 2015 | 04:41 PM
  #145
silthos's Avatar
A little bit more progress on my car. Just the top pic is my stuff.
Old Jan 19, 2015 | 07:45 AM
  #146
silthos's Avatar
Update: Waiting on a new axle from mitsubishi.
Old Jan 20, 2015 | 09:33 AM
  #147
nunyas's Avatar
what happened to your axle?
Old Jan 20, 2015 | 10:08 AM
  #148
silthos's Avatar
Boot was torn and they recommend replacing the whole axle. I'm sure some other stuff was wrong with it also.
Old Jan 28, 2015 | 01:28 PM
  #149
silthos's Avatar
Update: Car is up and running. Just waiting to get tuned now.
Old Feb 2, 2015 | 02:28 PM
  #150
rustybucket's Avatar
What a monster!
Is it a reliable car with all that power?
