Fp Red Dyno Results
I'm gonna bet that it's because a lot of the pre-assembled wiring kits that you get do not use OEM quality plugs/connectors. As a result, you get loose pins inside the connectors which often leads to unreliable performance. In the end, a lot of people prefer to "splice" into the wiring to ensure a solid connection that's 100% reliable.
A lot of people feel the same way about injectors and Plug-n-play clips; they'd rather use pigtail clips and splice in than to risk a blown motor because one of the clips had a weak/loose pin connection.
http://www.evoxforums.com/forums/showthread.php?t=90898
Check This Out. This Is When I Was Going To WIre My Pump UP. I Still Have It If You Want It. I Don't Think There Is Anything Wrong With The Connectors In This Kit.
I was able to get back on the rollers at my friends shop. Today was extremely hot and humid (Louisiana weather). The car is down on power due to weather conditions but I am extremely happy with my build so far. Here is the dyno sheet and video.
