Cold Air Intake
Old Nov 10, 2012 | 06:48 AM
majinfajita's Avatar
Originally Posted by richardjh
You and me both, mate!
Rich
NICE
Old Nov 10, 2012 | 03:57 PM
richardjh's Avatar
Oh yeah, and from an ECU perspective, heaps of engine management stuff depends on measured intake air temp... which occurs at the MAF housing, before the turbo.
The "Load" used for fuel map lookup is adjusted based on IAT.
Timing is retarded 1 degrees when IAT is around 47C, 2 degrees @ 58C and 3 degrees @ 85C.
RAX Patch adds boost control tweaks for IAT-based adjustment of WGDC. The higher the measured intake air temp, the less boost you'll get.
Rich
Old Nov 10, 2012 | 05:28 PM
RalliMark's Avatar
I guess Ill just stick with my stock evintake thats the DIY short ram for the time being . When I go fp green what intake would everyone suggest or should I just stick with what I got?
Old Nov 21, 2012 | 04:29 PM
myred3kgt's Avatar
This is what I did
Old Apr 14, 2013 | 05:47 PM
Rex87's Avatar
Does anyone have the AEM cold air intake? It looks like it replaces the stock air box, so I'd assume hyrdolock would not be an issue. But would installing it require a tune? Would I run into any issues with the "check engine" light or ECU, as the MAF sensor and stock wiring harness appear to be integrated with the install?
Old Apr 14, 2013 | 06:24 PM
billyboy1's Avatar
yep, i've the aem intake - it is a nice bit of kit with the filter etc all enclosed and haven't had any issues with water ingress. improved the flow and looks good in the engine bay. re the tune, if you bolt it on without out a tune, it will lean out your car, so would advise a tune once installed
Old Apr 15, 2013 | 08:35 PM
Rex87's Avatar
Thanks, but could you please clarify what "lean out my car" would result in?
Old Apr 15, 2013 | 10:12 PM
Rall1boy's Avatar
Very likely it would kaboom your motor if leaned out too much....too much air, not enough fuel.
Old Apr 28, 2013 | 01:56 PM
Guydoune's Avatar
I got the injen CAI that goes behind the trans cooler but I want to upgraded my turbo to an evo turbo and a bigger intercooler. Will my CAI and my intercooler piping still be compatible?
Nasty661X
Oct 13, 2012 01:49 PM
bowchicka777
Jan 4, 2012 06:53 AM
Evo8RLK
Mar 30, 2011 09:26 PM
Beardly P
04-06 Lancer Ralliart How To Requests / Questions / Tips
13
Mar 13, 2011 04:15 PM
