ralliart maf adapter pipe inside diameter
Hi guys, i have an 05 ralliart and from what i have found the MAF sensor is the same from 04-2012 for the RA not sure about the evo if someone can comfirm that. Im wondering what the piping inside diameter is because i am looking for a larger diameter pipe then my 05 ralliarts 2 1/4" ID stock MAF tube piece.
If the yours guys stock ID is about 2.5" and someone has just the pipe they would sell or knows where i can get just the MAF pipe in an aftermarket application again with a 2.5" ID please PM me thanks
yeh it does and the number on my sensor is MR985187, which was the same in a few pics i saw online. i would be interested in a stock tube if the ID is 2.5"
to answer my own question
http://www.treadstoneperformance.com...r+Adapter+Pipe
make s a pipe with the adator on it for 69 or jsut the adator in two different pipe sizes for 39
i spent most of my time searching keyword adapter turns out theres a few companies that make a "flange" (treadstone and jm fabrications),does anyone know where i can get a cheap one from? cheaper then 35$ or have one used?
i never said i wouldnt spend 69$?? i can make a flange at my CNC shop for free that will actually fit thats easy, but itd be nice to buy one save a bit of time unfortunatly thoese engineers didnt make one in a 2.5" piope size so the two that they have are goona have a big contour difference and im not filling that with tweld. as for the 70 id perfer to put that towards the cost of my cams ecu and timing control that i jsut bought if i could
OEM EvoX MAF tube. ~2.75 almost all the way through, including MAF section, then flares out at the one end to ~3".
Click to enlarge:
Attachment 198556
Attachment 198557
Click to enlarge:
Attachment 198556
Attachment 198557
Here ya go. Same as before, click to enlarge:
Attachment 198676
Attachment 198676
Im currently looking at buying an AL piece about 10$ and machining it into 2 flange adapter like the tread stone one but for a 2.5" ID tube, thanks for your help didnt mean to waste your time but if i decide otherwise i will send u a pm about buying your part
senate6268
Lancer Engine Management / Tuning Forums
91
Dec 26, 2022 12:20 AM
ETS Michael
12
Feb 19, 2015 01:27 PM
rice_rocket88
Mar 22, 2014 06:55 PM
