UR 800cc inj. in Ralliart, what else is needed?
Old Jan 10, 2013 | 02:06 PM
09Ralliart412's Avatar
Alright bear with me guys, I havent posted here or been on here much so please redirect me if there is already a thread about this subject.
I found some 800cc injectors for the Ralliart. I was curious what else I would need to do to support these injectors? I'm about to buy a turbo back exhaust and start off with the AMS performance stage 0 with the ECU flash and boost pill. Thanks!
Old Jan 10, 2013 | 02:08 PM
bjax4B11T's Avatar
Definitely upgrade the Intercooler and UICP before anything else dude
Old Jan 10, 2013 | 02:21 PM
RussellDaniel's Avatar
Injectors are gonna need to be scaled for sure.
Old Jan 10, 2013 | 03:05 PM
nunyas's Avatar
for bigger injectors... you need a bigger fuel pump and a turbo that's bigger than the EvoX's turbo....
Old Jan 11, 2013 | 06:18 AM
crak's Avatar
+1 on the fuel pump and you need an ECU tune too.
Old Jan 11, 2013 | 08:19 AM
silthos's Avatar
800cc injectors was good for 344/322 on a dyno dynamics running a fp red with stock fuel pump.
Old Jan 11, 2013 | 04:30 PM
03chi-town0Z's Avatar
Bigger injectors are not going to be necessary until much further down your modification path. Neither the stock RA turbo, nor a stock X turbo will max out your stock injectors unless you are planning to run e85 fuel.
Unless you already have them, I would recommend investing your money elsewhere, first, as you will not see any gain, whatsoever, from the injectors at this point in time.
Krisko
Mar 10, 2014 06:49 AM
twinturbogreg
Sep 27, 2010 12:12 PM
Chris@AMS
72
Jan 5, 2010 01:32 AM
kirkklau
20
Nov 4, 2008 11:39 PM
mike2016
AEM EMS
16
Feb 27, 2008 09:39 AM
