SST transmission replacement
I did a search and i cannot find the answer i am looking for.
Ok so i found a 2012 sst transmission for the Ralliart and was wonderind if it will work on the 2009 ralliart. The place that has it says something about it not being compatible b/c of the year difference.
My thinking is that the transmission will work regardless of year b/c the models are the same. let me know what you guys think.
It's should work, the only difference I think there is between my 09 and someone's 12 is the color LCD and my plugs were a heat range colder from the factory. I'd really talk to Jeremy at SSP performance before I'd consider a transmission swap. He can get everything needed to fix your TC-SST for way cheaper, and it'll handle high horsepower
I can be emailed at jason@sspperformance.com
vaqusis
56
Sep 29, 2017 08:35 AM
figures cross.
