My Setup, do i need a higher or lower psi actuator?
Old Feb 18, 2013 | 10:21 PM
mirage4g64's Avatar
here is my setup as now looking to put everything on and get it tuned, just once. My question is do i need a uprated wga? should i get a higher psi than stock or lower, or none? can i just dial in more psi with the EBCS? im looking to get as much out of this as i can, possible ill be using meth to keep the IAT's down also.
X turbo
X mani
3" TBE
4" FMIC
Hard pipes
IR ARO 3 port EBCS
Omni 4 bar MAP
Old Feb 19, 2013 | 05:51 AM
03chi-town0Z's Avatar
The EBCS will pretty much get you to where you want to be. The upgraded actuator would be a very minimal difference with only slightly better boost building and holding potential. If you are after every last ounce of power, go with a higher pressure spring (18psi is popular) but cost/benefit ratio is not worth it to a lot of people.
Old Feb 19, 2013 | 11:01 AM
mirage4g64's Avatar
thanks! i was going to buy one anyway because the one that came with the used turbo looks kinda sketchy
wrinkly
Mar 6, 2017 02:38 AM
longdingydong
Sep 15, 2011 02:48 PM
BluEVOIX
11
Apr 14, 2010 11:08 AM
evoland
Oct 14, 2004 07:01 PM
