Boost problems!!
Old Oct 14, 2004 | 05:59 PM
evoland's Avatar
Boost problems!!
Hey guys I got my utec yesterday and installed it the same day. I have an EBC and I talked to the guys at Turbo xs and they said if I wanted the utec to control boost, that I should remove my EBC and hook back up the stock boost soleniod and ABC for the UTEC. I decided that I would and today I did just that. However after installing the stock setup I am only boosting 10psi now and nothing higher. I have tried to make sure my connections were right, but the boost is still at 10psi?? I tried to make sure the hoses matched the manual from turbo xs?? Just wondering if anyone had another diagram or picture. Maybe something with my EBC?? Please help guys!!
Old Oct 14, 2004 | 06:43 PM
justrick's Avatar
did you put both stock lines with both restrictor pills back in place
with larger line or no restrictor pills youll get nothing for boost
rick
Old Oct 14, 2004 | 06:59 PM
VTECH8TR's Avatar
jutrick is 100% correct, i was having the same problem after deinstalling a GReddy ProfecB and i did not use the stock lines. I read and asked questions and that was my problem.
Old Oct 14, 2004 | 07:01 PM
masterevo's Avatar
I have the exact problem and there is several threads on here that you will find helpful. All you need is the first restrictor pill. You can do away with the other one. It's 20 bucks from mitsu!!!!
nonojoe66
Oct 27, 2009 10:47 PM
Vivid Racing
13
May 27, 2007 02:45 PM
EVO8LTW
Jun 20, 2005 09:24 AM
BSREVOLUTION
Feb 23, 2005 05:37 PM
an0ther
Nov 4, 2004 12:05 PM
