ACD Pump same as Evo IX??
Old May 11, 2013 | 01:24 PM
total0wnage's Avatar
Does anyone know if the our pumps are same as EVO IX? I spoke to someone before and they said the guts and most of its same but not sure if its direct swap. If its a straight swap then I can easily get my hands a low mileage evo ix pump cheap.
Old May 12, 2013 | 07:17 PM
Ruff-Shaw's Avatar
No pumps are not same , what exactly do you need to know
Old May 12, 2013 | 09:00 PM
My pump is dead, i came across a IX pump just wondering if it would work since it was cheap. Im trying to find a solution but dont have $600 to spend on rebuild right now
Old May 13, 2013 | 06:13 AM
DatRAzn's Avatar
The pump in my car has been dead for over a year now (no desire to fix), you can drive with it inop still. You'll just lose the nifty center diff locking, the drivetrain will be somewhat similar to a 4x4 truck. .
Get frugal, and save up money to get it rebuilt or replaced correctly. I don't believe one from the VIII/IX will fit correctly, however an X pump should be a direct swap.
Old May 13, 2013 | 09:22 AM
Ruff-Shaw's Avatar
Can't swap Evo x to Ralliart either.
Old May 13, 2013 | 04:25 PM
03chi-town0Z's Avatar
I know they're not the same part, but I'm curious if this is actually the case because the castings look the same, but the second set of ports is just not drilled through on the RA pump. I've been wondering if you could just install some generic plugs on the unused ports and rewire the connectors...
Old May 13, 2013 | 06:32 PM
DatRAzn's Avatar
Plug up the AYC ports and rewire the rest? Sounds like it might work to me.
It'd probably be cheapest, or most effective, to have acd-tuning rebuild the ACD pump in any case. I believe that they use better material that's less likely to corrode.
Old May 14, 2013 | 05:54 AM
Ruff-Shaw's Avatar
It won't fit . You don't have clearance for IX pump and you would need heavy mods to do with no guarantee that motor will run with ecu. I tried this and can tell you from my experience it is most economical to rebuild your existing pump I did many with great results.
Old May 14, 2013 | 05:56 AM
DatRAzn's Avatar
^03chi is talking about trying to retrofit an X pump.
Did you try both the IX and X pumps? Or just the IX?
Old May 14, 2013 | 06:42 AM
Ruff-Shaw's Avatar
Pump from X fits for Ralliart however you will need to close 2 fluid lines on pump and fabricate plugs for 2 solenoids ( or just leave solenoids in place ) Electrical plugs are same. Problem is that Evo x pump cost more than one for Ralliart so I don't see point doing this.
Old May 14, 2013 | 07:15 AM
More availability in used part market from people removing pumps for race applications and the overall higher number of X's produced vs RalliArt
Old May 14, 2013 | 07:29 AM
Ruff-Shaw's Avatar
Unhappy
That is correct , however most guys keeping old pumps in garage as non working spares and won't sell them.
kaj
For Sale - Part Outs
Jun 3, 2016 08:10 AM
fatboyslim86
Jan 14, 2015 07:33 AM
Mark_L
Jan 4, 2014 03:56 PM
DONNOD
Apr 13, 2013 03:14 AM
meckert
Nov 15, 2012 03:46 PM
