I might have a problem????
Old Nov 8, 2013 | 02:51 PM
hotkupa's Avatar
I just removed the bottom tray cover from the engine and noticed that the entire area where SST meets the engine is wet with oil. Please help
Old Nov 8, 2013 | 03:30 PM
neogeo64's Avatar
The picture is to small to tell whats going on. upload it in full res.
Was the sst repaired at any time? hopefully not a bad seal between the sst and block.
Does it smell like SST fluid (sort of like crayola crayons), transfer-case lsd fluid (smells real bad) or engine oil ?
Check some of these areas out;
If SST fluid:
1.Check drain bolts on sst are torqued to around 25 ft lbs
2.Look near driverside wheel on SST to make sure it's not leaking from filter area as it could be the filter holder is cracked or not on all the way.
If oil, follow it to source:
1.might be leaking from oil pan (known issue on RA /Evo X) in that case drain oil, use supper thing putty knife to work off old pan, clean off old sealant from block/pan, apply new sealant and bolt back up.
2. might be leaking from head gasket near rear manifold. (have shop fix this)
If transfer-case:
Check the drain bolts or square access panel (i seen my friends ra have a bad seal there)
Old Nov 8, 2013 | 03:39 PM
hotkupa's Avatar
I just made the picture bigger. I checked the oil level its perfect. I am afraid its the sst leaking. My car is not exactly stock so I do not want to take it to the dealer.
Old Nov 8, 2013 | 04:51 PM
splattj's Avatar
You can tell which kind of oil it is by smell. Engine oil will smell faintly of fuel or just like... engine oil. SST oil will smell...awful.
Old Nov 9, 2013 | 05:54 AM
SSP Jason's Avatar
Could just be the SST drain plug or filter housing.
If not, check around the black pan (or SSP pan if you have).
Old Nov 9, 2013 | 12:48 PM
hotkupa's Avatar
I checked everything and one thing is certain it is not the SST filter housing. That is the only area that is dry. I cleaned up everything will drive it for a week and see where the wet areas are. I did not smell like the the SST fluid .......so hopefully that is not it. Thank you for all the responses and suggestions. Will update.
Old Nov 9, 2013 | 01:55 PM
vaqusis's Avatar
There is a known issue with the housing for the SST filter cracking. It's crappy plastic. Any qualified mitsubishi dealership should replace it for you. Mine cracked when they replaced the filter a while back.
Old Nov 10, 2013 | 08:54 PM
neogeo64's Avatar
looking at that picture it looks like oil and you can see the path from I higher location flowing down from the stains. Double check the bolts around the oil pan.
I had the oil pan gasket leak around 25k miles.
I think you on the right track though, clean it all off, leave the under tray off so you can easily check every day or 2 until you find the source.
Old Nov 14, 2013 | 07:05 AM
gaabbee's Avatar
have you replaced the fluid ever? if so what did you use? I'm leaking too. Going to swap fluid and see what happens
Old Nov 14, 2013 | 04:16 PM
hotkupa's Avatar
I changed the fluid and filter at 19k. 33k now.
Old Nov 15, 2013 | 04:26 AM
gaabbee's Avatar
What fluid did you use? I've heard some aftermarket fluids will leak...which is why I'm putting diaqueen in now.
Old Nov 15, 2013 | 03:34 PM
neogeo64's Avatar
after you cleaned it up.. have you been able to locate the source yet?
Old Nov 16, 2013 | 01:16 PM
hotkupa's Avatar
I used oem fluid and filter.
Old Nov 16, 2013 | 01:20 PM
hotkupa's Avatar
Not yet. My car is not my daily driver. I only did about 40 miles since then. Will check next weekend. I think I might have idea what it is..........I will feel like a retard if it will be what I think it is!!!
hotkupa
17
Feb 6, 2024 05:08 AM
hotkupa
10
Jul 10, 2016 04:42 PM
hotkupa
Jun 11, 2016 10:51 AM
hotkupa
For Sale - Part Outs
Nov 8, 2015 10:12 AM
hotkupa
For Sale - Cars For Sale
Sep 9, 2015 08:46 PM
