SST behavior after applying sudden throttle
Old Mar 16, 2014 | 04:22 PM
plastus's Avatar
Hi everyone. I noticed some interesting behavior with my SST lately and don't know if this is normal and I've never paid attention to it, or if something is up. When cruising at some speed with no throttle and I apply sudden moderate throttle, the revs jump a bit (250 to 400rpm or so) before "catching". If I apply the throttle more gradually in a gear, or if I give it WOT from 5-10% throttle it behaves as expected without rev's bouncing up. Could it be the clutches slipping? I also have some very soft shifts w/ rev bleed for gears 1>2>3 after a cold start until the car warms up.
Appreciate any feedback!
Old Mar 16, 2014 | 06:12 PM
AlDim's Avatar
They are most probably slipping. How many kms do you have on the car and have you done an SST fluid change?
Old Mar 16, 2014 | 06:14 PM
plastus's Avatar
The transmission only has 10k miles on it or so since it was replaced so it has original fluid.
Old Mar 16, 2014 | 06:31 PM
danike's Avatar
You should record the tachometer and upload the video. I'm sure the community could troubleshoot the issue better.
Old Mar 16, 2014 | 06:42 PM
neogeo64's Avatar
normal or sport?
Old Mar 16, 2014 | 06:46 PM
plastus's Avatar
Both modes. Oddly enough, I started noticed the mushy shifts when cold after I replaced my HKS air filter with a Cosworth one. I replaced it with an OEM Evo X/Ralliart filter and reset ECU learning thinking it could be caused by that. I'll see this week if that made any difference. If I'm in 5th gear at 2,500rpm with very light throttle and then go WOT, the revs do not bleed and it feels like the clutches are holding strong. The rev "blips" only occur if I'm completely off the throttle and then get on the gas in a more aggressive fashion. Are the clutches completely disengaged if there is no throttle input and the car is coasting at 40-50mph? Could the blip just be associated with them engaging as engine speed rises a bit?
ezzey
May 9, 2016 09:40 AM
mxc1868
Mitsubishi TC-SST Discussion
Mar 26, 2016 02:35 PM
ottoman
Aug 2, 2012 07:03 AM
QtLancer
Lancer Aftermarket Forced Induction Tech
Aug 5, 2004 12:40 PM
