Ralliart & Evo X MR TC-SST Beta Testing. Flash with Tactrix
Old Sep 18, 2018 | 02:26 PM
  #256
hixlancer's Avatar
Veteran: Army
I’ll look when I get home at my reg files and the directions. That line just means you’re 64bit
Old Sep 18, 2018 | 02:49 PM
  #257
superchikn's Avatar
OK great thanks. it communicates with car just fine but is still locked to just reading it.
I decided try it again but now my registry editor has disappeared. Very confused on this. Taking a break far easier to me to rebuild the engine ha.
Can someone please explain why this will not install to c: program files? I changed the value but it goes to its own folder.
On Windows 7 Professional 32bit, should i use a different value or path name?
Old Sep 27, 2018 | 10:27 AM
  #258
superchikn's Avatar
I finally figured this out if you have similar problems getting it to work, check the status of your program files folder under "properties ", mine had been set to read only and was causing all my grief.
I changed the permissions, re started the computer and it went without a hitch after.
I cannot believe how much better the car shifts i had honeslty considered trading it on a ford focus RS the transmission was so scary especially after the horror stories ive read.
Ive still yet to do the teach in, but i am very pleased with the results so far.
If anyone has a Ralliart that has wacky shifting this is well worth the effort.
Ive got the 2010 files loaded (my car is 2011), am curious if the 2011-2015 Evo files are better?
Old May 21, 2020 | 08:50 AM
  #259
ipointatthesky's Avatar
Have you gotten any updates regarding this? I have a 2011 Ralliart.. which file should i be using? The one in folder provided for 2009-2012 Ralliart which is 8631B002_dio30.cff and 8631B002_dio30.flpart. I assume that is the correct one but from reading, it may not be the best file to use?
Old Mar 23, 2021 | 09:29 PM
  #260
ebrahimelbadry's Avatar
thank yuo
Old Nov 18, 2022 | 02:22 AM
  #261
2009ralliartat7's Avatar
hey how come i cant access the files and it says I need permission
Old Dec 1, 2022 | 01:46 PM
  #262
Torcano's Avatar
Because the files are from 8 years ago, and there are better options available today. Also, this forum is dead. Talk to NRG-OPS about S-Sport 2.0.
vaqusis
Mitsubishi TC-SST Discussion
21
Sep 20, 2018 07:28 AM
Slee256
Jan 8, 2017 09:15 AM
richardjh
Driving Techniques
Nov 2, 2011 01:49 PM
RussellM
MitsubishiParts.net - WA
Jan 4, 2011 04:21 PM
RussellM
26
Jul 15, 2009 02:54 PM
