Exhaust Manifold Cracked
Old Mar 1, 2016, 12:32 PM
Veronica's Avatar
Angry Exhaust Manifold Cracked
It is loud!
Sounds cool and still appears to make full boost...
So... what are my options?
I am not eager to get another OEM one - because they crack (poor design).
The only aftermarket one I am aware of is MAP (fro EVO X only)...
So...
Any other RA exhaust manifold options?
Thanks!
Old Mar 3, 2016, 07:25 PM
silthos's Avatar
Unfortunately no other option besides oem for ra turbo.
Old Mar 4, 2016, 12:41 PM
Veronica's Avatar
That is what I thought - but worth checking with the forum just in case...
Old Mar 10, 2016, 11:53 PM
drivejumpfly's Avatar
That sucks. How many miles are on your car? I have a warranty on my car just in case mine cracks before I do the Evo X swap, or I decide to swap cars completely lol.
Old Mar 14, 2016, 12:43 PM
Veronica's Avatar
109k ;
Old Mar 17, 2016, 11:36 AM
cjsabaki's Avatar
A guy on facebook name Mi Mel is working on stock manifolds, ported and coated, welded if need be, and will be selling them here shortly.
Chris
Old Mar 17, 2016, 11:39 AM
cjsabaki's Avatar
If its not bad, a good welder can weld it on the car ( if the crack is on the top ) typically cast iron needs to be heated cherry red before welding and stress relieved after BUT a minor crack can be repaired by drilling small holes at both ends of the crack, inletting the crack itself with a grinder, running the car till the manifold is HOT and welding the crack with the correct welding rod.
Done early, this can save the mani.
Old Mar 18, 2016, 11:36 AM
Veronica's Avatar
Chris
Keep us informed!
Old Mar 19, 2016, 07:25 PM
Originally Posted by Veronica
109k ;
I hate that it happened to you, but I am glad to hear that it was over 100K miles before it happened. Do you think they can repair it by welding it back together?
Old Mar 21, 2016, 08:30 AM
Veronica's Avatar
My guy seems to think so. Needs "special" high nickel content solder.
My Lovely Bride will bring it to him Wed and I will let y'all know what I find out...
Other option is to do it myself with "ThermoSteel"...
Old Mar 21, 2016, 10:12 AM
jkennedy293's Avatar
Mine broke with about 90K on it. Apparently they all crack on the No. 2 (?) runner. A replacement stock manifold and gasket can be had for about $600. Install isn't too hard, just have to drench the bolts in PB Blaster.
I'm planning on replacing mine with a factory unit and having the old one welded in case the new one cracks before I get rid of the car in a year or two.
Old Mar 22, 2016, 09:16 AM
cjsabaki's Avatar
ALL of the epoxy / silica / quiksteels I have tried will work a few days to a week, but they harden and become brittle and shatter, temporary fix only.
I work in the Autoparts industry ( 12+ years...) and have tried every compound out there, they help temporarily and if you use a thermotech type ( fiberglass ) header wrap over the top of the repair, it buys you more time before the jet hot exhaust gases burn thru even the wrap itself. ;(
Old Mar 22, 2016, 11:45 AM
Veronica's Avatar
Thanks for the heads-up.
Old Mar 22, 2016, 11:46 AM
Veronica's Avatar
Pix of the cracks.
Old Mar 23, 2016, 04:45 AM
Yep. That's the exact same place mine cracked.
Quick Reply: Exhaust Manifold Cracked
