Boost failure
Old Jul 12, 2020 | 04:02 PM
tooltyme's Avatar
Boost failure
Hey just wondering next steps I would take to solve this issue,
Was out lastnight doing some brake boosts in super sport mode with stage 3 ACN Cobb tube (2013 Ralliart)
When driving home lost all boost, pulled a code P2263 waited till morning to Check found the middle joint on stock turbo piping between turbo inlet and air intake has come apart so I fixed and tested no boost still, but new codes p0068 and u0167
Cobb access point reads 25+/- 2psi on WOT
Cobb access point reads - 11 / - 12psi on high rpm throttle release
EBC solenoid is stock and original, boost pill has been removed, larger intercooler and mushroom air intake.
Old Jul 13, 2020 | 10:40 AM
tooltyme's Avatar
EDIT this is normal running numbers
after the whole pipe burst im doing maybe 1psi -5psi from first to sixth gear
Old Jul 14, 2020 | 09:59 PM
markfromNZ's Avatar
So the joint between the MAF and turbo came apart?
seems weird
check for a physical boost leak post turbo, BOV stuck open etc
Bmfromel
Nov 17, 2017 05:57 AM
six40
Mar 7, 2016 02:52 PM
Robs3vox
Cobb AccessPORT
Feb 26, 2014 02:17 PM
Funsuby
Jun 28, 2012 09:00 AM
AJR-Coco
Dec 9, 2009 04:49 PM
