How To: Locate and Install Boost Pill
It should be a little less than an inch from the T- connector.
Make sure when reinstalling the boost pill that the bigger, open end faces upwards towards the outlet pipe, the smaller end facing downwards. Had a scare yesterday with this and reinstalled it backwards, overboosted and threw a bunch of codes. Reinstalled it correctly after that, car's running fine now.
What do you mean above by outlet pipe? nipple ? the small end of pill should be closest to T connector?or? Please verify....
Use a little screwdriver to break the seal and help you pry it off. Thats how i got mine off the first time
I found a slight twisting motion helped too. I made sure the hose clips were slid off the nipple then pulled hard using a slight twist. Only ended up with 1 cut and 1 bruise.
hmmmm that sounds a little more interesting than it actually was.
Guys, I found the AMS boost pill on Ebay, but they have the following note:
" Your car MUST have a tune to use this boost pill
Failure to tune your vehicle after the installation of the boost pill can result in engine failure."
What is that suppose to mean? Do I have to re-map the ECU or what?
