License Plate Install
Quick questoin for you RA owners like me out there. I just got my plate's waiting for my frames before i put them on. Anyways, i was going to mountfront plate in the middle and i see 2 very small pre-drilled little bump where screws would go.
My question is do i need anything special to drill into these and mountmy plate?ihope i dont have to just put two screws in and leave them like that, i feel like it would rattle out and potentially fall off from overtime shaking abuse you know?
Lemme know what you guys did if you can, Thanks a lot!!
the car should have come with two rubber/expandable nuts.
BUT.........if you feel you need to have a front plate....
......do yourself a favor..go to your dealer and order the evo-x bumper mount
it will cost about 35$ and maybe they will discount the price since you just bought the car.
........and........YES , it will work on the ralliart.
well yeah i need to have a front plate im prety sure in california its required by law. needs to be certain height from ground also ( like you cant leave in your interior dash ) you live in cali ou should know this. but ty
i had the factory evo-x mount on my '08 gts. it looked good........
...........well , better than in the middle.
I think front plates look....strange when it's in the middle of the bumper on our RAs. Get a side-mount plate
. You don't necessarily have to drill holes in the bumper, just get some industrial strength mounting tape.
U should try this:
http://www.youtube.com/watch?v=C1zIG...layer_embedded
It may sit a little low. but atleast u got it when u need it.
I had the bad luck of them telling me that they couldnt get the mount and so i told them to jst drill the holes so i could put the mount in and they obviously drilled them in the center now i have to figure out a way to cover the wholes and then side mount it
I just got the Evo side mount myself, I have yet to install it (terrible weather in NY the past few days) I am hoping when I take my front plate off that the wholes they had to drill will not be extremely obvious. If anybody finds a good way to make it look good at least at a distance definitely post how!!
-Taranis
holes/grommets are 1/2 inch in diameter. save you some headache, i hope, while you're out trying to find the right size plug at home depot or wherever. good luck, let us know what you find
Where get I get such tape? I've been trying to find this out for a while.
