Running the Fog lights without headlights
Old Jan 24, 2018 | 03:47 PM
  #31
strykr's Avatar
Veteran: Canadian Forces
Its not Mitsu specific, its any vehicles that use Mitsu's ETACS system.
You NEED an openport 2.0 and for software it is called ETACS Decoder.
You cant make the fog light switch turn the headlights off, but they can be independently turned on and off. If you want the headlights off you just need to use the switch to turn it off. If you have DRL, just pull the fuse and they should be off when the switch is in the off position, if not you can also turn the drl feature off in the program, but my car didn't need it in our market.
As for turning a rear on and off, I don't have that feature and am unsure how it is controlled but I'd assume you can edit that feature in the program.
Old Jan 24, 2018 | 06:40 PM
  #32
-=Mr B=-'s Avatar
Well, the OpenPort 2.0 should pretty much be on the way already, and i'll try and find the ETACS Decoder. Thanks.
Old Jan 24, 2018 | 10:07 PM
  #33
strykr's Avatar
https://etacsdecoder.com/forum/
This is the official website, always use the newest update every time you use this program check!
Also make sure you READ the guide! There's important info and if you mess up he says it's your fault for not reading it.
Kevvsworld
Jul 9, 2021 09:29 PM
shacomaster
Lancer How Tos / Installations
Dec 5, 2017 02:13 AM
Jovan Caro
Jun 27, 2017 09:30 AM
Spartan716
Mar 30, 2017 04:38 PM
Raptord
Jun 5, 2016 07:11 PM
