Ralliart Foglamp Delete - Ghetto Style!
Thanks for the data Rich. Pick up a 5.5" SPAL fan and a cheap radiator fan install kit that pushes in-between the cooler fins and you'll be watching those temps drop... or at least stabilize
Unfortunately, that eBay company only ships to US addresses. So it's a bit more of a pain from Oz.
I'll be happy with 3 degrees C rise a lap at my local motorsport haunt - as long as the starting temperature is lower. As it stands now, temps just do not drop between runs - so a fan pulling air through the cooler should help a lot.
I've really got to look at fitting an Evo X engine oil cooler too. If this is what's happening with the trans fluid with a (small) cooler, I don't like to think what's going on with the engine oil, which doesn't have one at all.
Rich
Rich
Hiya.
A few people have asked if I had scans or plans of these old things. Well...
I've found some old traces I made of the plastic cutouts. It seems I traced around them before shaping them with the heat gun.
Four zipped JPGs are attached to this post. The parts were larger than the A4 scanner I own now, so I did two scans for each side. You'd want to print off a pair, align the two A4 printouts, stick them together to make a usable complete template, and go from there.
Apologies for the low quality. These have sat on top of a cupboard since 2011 - only rediscovered by chance, when I was looking for something else!
Rich
Rich
velocityhead
246
Jun 1, 2018 02:22 PM
chaotichoax
Aug 5, 2017 06:28 PM
RallyDSM
Mar 19, 2017 07:05 PM
EGbeater
Sep 19, 2016 05:50 PM
FS[West]: CA - LA 2008 Evo X GSR SSS Apex Silver
jessemoody
For Sale - Cars For Sale
Jan 14, 2016 11:14 AM
