The RIGHT WAY to Flush your SST Trans
Old Oct 8, 2014 | 04:38 PM
  #121
Vegeta_Ra's Avatar
Gotta do mine very soon thanks for the write up!
Cheers
Old Dec 2, 2014 | 01:38 PM
  #122
Sikilla's Avatar
Great write up
Old Jan 30, 2015 | 08:50 AM
  #123
huckin01's Avatar
Killer write up, great pics, good job, I will be referring to it a few times this evening I am sure.
I ended up changing it last night as well as the motor oil and diffs, used Redline DCTF for the trans. after talking with them.
Old Feb 1, 2015 | 04:45 AM
  #124
08Lancer89's Avatar
No problem guys I also have a write up on the transfer case and rear diff change.
Old Feb 16, 2015 | 08:54 PM
  #125
sesman1234's Avatar
Did my fluid change over the weekend, took like 4 hours because I was going slow... took the battery out to find the fill hole, not sure if that was required. Drained the lines as described in the how to
Used 8 liter FFL-2 and the 30 dollar filter bought online ssp, this was for the 100000KM fluid change, fluid was brownish compared to the stuff right out of the bottle, right away ive notice the clunk that I had go away from braking hard shifting down from 2 into 1, everything else feels good so far...
Old May 13, 2015 | 04:42 PM
  #126
NsRhea's Avatar
Never would have thought of the mineral oil cleanse. Good write up.
Old May 30, 2015 | 07:16 PM
  #127
1SchwedeEvo's Avatar
Very helpful! taking care of this in a couple days.
Old Jun 10, 2015 | 10:52 AM
  #128
12longz's Avatar
Thanks !
im going to try this soon thanks for the how to !
Old Jun 11, 2015 | 06:26 AM
  #129
huckin01's Avatar
I ended up using the Redline DCTF
http://www.redlineoil.com/product.aspx?product=31004
I have about 8k miles since the change and immediately noticed around a 2 mpg gain on fuel economy from when the car was new and much, much better shifting.
Old Jun 11, 2015 | 01:58 PM
  #130
08Lancer89's Avatar
No problem guys glad to help
Old Jun 14, 2015 | 10:51 AM
  #131
12longz's Avatar
Exclamation
where do i find this ?
Old Jun 14, 2015 | 11:32 AM
  #132
08Lancer89's Avatar
Look below in similar threads its right there or go on my username and click on threads started by me
Old Sep 21, 2015 | 06:42 PM
  #133
Kustom09art's Avatar
Thanks got the How-To it definitely was a life saver !!
Only thing was that i couldn't find the overfill plug for the trans.
Old May 9, 2016 | 10:25 AM
  #134
jdogstoll23's Avatar
great advice, taking the plunge in a couple days
Old Jun 19, 2016 | 10:01 AM
  #135
BoostInside's Avatar
I'm going to flush mine today. I'm planning to drain everything, including the cooler. Fill with mineral oil, shift through the gears a bit, let it soak, drain and then fill with the liquid gold.
I'm going to take a bunch of fresh pics as we seem to have lost most of the shots showing drain, fill and level check locations.
Im at 52k and havent changed since 3k so I wont be surprised if some nasty sludge comes outta there. Thankfully, I dont beat on her since it's my DD. Very few launches and no track time.
I had some pro help from a friend the first go-around so depending on how long it takes me to do it solo, i'll go for transfer case too if possible.
Cheers! ..and Happy Father's Day!
