The RIGHT WAY to Flush your SST Trans
Old May 20, 2013 | 09:37 AM
  #76
Fuego's Avatar
Originally Posted by nmilsaps
Thanks for the write up... Changed it this past weekend.
Few notes: I did not mess with the Trans Cooler
My 2010 only has 2 drain bolts. Is that correct?
I removed 5.7L of old fluid through the 2 drain bolts and filter housing.
I added 7.5L of mineral oil, drained about all of it.
I added 6L of new fluid.
Shift are good, better than before. No warning lights or any errors.
So did I miss anything? Should I add the extra 1.5L?
Did u drain the transmission cooler and filter housing? What year is ur car? Some have 3 bolts.
Old May 20, 2013 | 10:58 AM
  #77
DatRAzn's Avatar
Ideally, you should only fill what you take out.
However, there is a fill level bolt on the driverside of the transmission. Make sure the car is level, pop the bolt out, and fill slowly until it starts dripping out of the fill level hole. I say slowly, because each little drop is worth approx $7.95.
Old May 20, 2013 | 04:44 PM
  #78
Fuego's Avatar
+1 but u should be able to drain a little over 7oz when u do a proper flush. If u did drain everything and don't get about 7oz I would use the fill hole to fill it properly.
Old May 21, 2013 | 06:47 AM
  #79
nmilsaps's Avatar
I drained the filter housing & the main reservoir, not the cooler. It's a 2010.
Do you mean 7 Liters?
That's what I did, took out 5.7 liters and put back in 6 liters. Since I didn't drain the cooler, then is tha why I'm missing the extra Liter or so? The confusing part (to me) is that I put 7.5L of mineral oil in and got it all (mostly) back out. So why didn't that stay in the cooler part, or did it?
Old May 21, 2013 | 06:52 AM
  #80
DatRAzn's Avatar
Yeah the cooler holds about a liter of fluid. So 5.7l out sounds right if you didn't drain the cooler.
Old May 21, 2013 | 12:17 PM
  #81
Fuego's Avatar
Sorry it's about 7L. I got 7.4L out when I did mine. If you don't drain the cooler then that fluid will still be there and mix with the new fluid u put in.
Old May 27, 2013 | 11:02 PM
  #82
robyn402's Avatar
Whoa.... how long have you been sitting on that nugget? Lol... I'm probably just blind
That will definitely make getting the proper level that much easier, shame we can't stick a dip stick in it... or would fabricating a dipstick on the fill plug work?
Old May 28, 2013 | 06:08 AM
  #83
DatRAzn's Avatar
I found it while looking at some drawings on Ford transmission last year. . Since then I've noticed a few other people who knew about it here and there.
I'm not sure a dipstick would work out of the fill level plug (or at all, really). With the proper amount of fluid, the fluid should be right at the bottom of the hole and just barely dripping out.
Old May 28, 2013 | 06:24 AM
  #84
Fuego's Avatar
I know I seen the SSP transmission pan with a dip stick a few times.
Old May 31, 2013 | 12:07 PM
  #85
nmilsaps's Avatar
Level check plug location
Old Jun 1, 2013 | 11:36 PM
  #86
robyn402's Avatar
^ score... gone are the days of measuring your fluid to get the level right
Old Jul 25, 2013 | 04:10 PM
  #87
robyn402's Avatar
curious i was doing some reading of other forums and it says the trans temp has to be 40ish degrees celcius to check the level via this bolt....
does it really matter? as long as you let the fluid settle should be fine right?
Old Jul 25, 2013 | 04:28 PM
  #88
Fuego's Avatar
Ummmm never heard about the trans temp lol... There is a fill bolt to make sure u fill it up if u don't measure how much u take out.
Old Jul 25, 2013 | 04:44 PM
  #89
neogeo64's Avatar
The fill bolt method is to fill it up till it pours out. put bolt back, start car and run it through the gears, then turn car off and open bolt and fill again until it pours out, this is to make sure the fluid gets to both chambers (odd/even side) and through the cooler lines (it might need to be up to that temp so that the thermostat kicks on the pump to fill these lines).
Old Jul 25, 2013 | 05:48 PM
  #90
robyn402's Avatar
yeah i just dumped in approx what i drained out... wanted to pull the level check plug just to be certain i got the right amount
figure after letting it cool down after driving should be sufficient?
