Gauge Wiring Question
Old May 7, 2012 | 08:21 AM
Jasoob's Avatar
I will soon be installing boost gauge/wideband gauges.
I've looked at all the really great tutorials and have a pretty good understanding of everything.
I have a really basic question:
The wiring for each gauge (ie. red/white wire for boost gauge), when I'm putting these into the fuse panel, what do they hook up onto? I'm guessing I pull the fuse out, wrap the wiring around the metal 'teeth' of the fuse and plug it back in?
That's the only question I have. Everything else seems pretty straight forward.
Old May 7, 2012 | 09:43 AM
TurtleRA's Avatar
Google 'fuse tap' that is the easiest thing to get, plus then you are running a separate fuses for the gauges instead of piggybacking off a fuse if you just wrap the wire around the metal prongs.
Old May 7, 2012 | 12:35 PM
Struc's Avatar
I tend to over-engineer things, but I ran a power wire from the battery to an aux fuse block I bought. Now I have all kinds of expansion capability.
I plan on hard wiring my radar detector, dual power outlet for GPS & cell charger, and all gauges (will have 5 total), as well as the power feed for my aftermarket radio, and possibly in the future an aftermarket amp. Thus, I have a lot of extra power needs.
Here is the block:
http://www.amazon.com/HELLA-H8496010.../dp/B000VU9D1Q
I also bought a small terminal block for a common ground that I plan on running back to where the battery connects to the body:
http://www.amazon.com/gp/product/B0058RW37S
For switched power items, I wired several of the fuse box locations to this relay which activates with the key on:
http://www.amazon.com/gp/product/B00009WC2Q/
If you want to go the simple easy way for just a couple gauges, then by all means get some fuse taps to feed the power.
http://www.amazon.com/gp/product/B00...ls_o02_s00_i00
Have fun!
Old May 8, 2012 | 09:02 AM
Jasoob's Avatar
Awesome with the fuse taps...but in theory, could I just connect the wire to the existing fuse without a tap?
Old May 8, 2012 | 09:10 AM
Struc's Avatar
In theory, you can do anything you want to do.
Just throwing out some better options.
A wire jammed in there could easily come loose by itself over time. It's best to come up with some sort of better solution.
Old May 8, 2012 | 09:57 AM
Jasoob's Avatar
Haha for sure! Thanks again for all the tips. I have to connect a boost and wideband into there. I might go with the fuse taps.
turbotaloon95
May 16, 2017 01:57 PM
EVO GOES VROOM
Apr 27, 2016 07:58 PM
mrwickd123
Aug 7, 2013 12:31 AM
cpunlamd
Jun 20, 2010 06:25 PM
NJ_evoIXgsr
Apr 19, 2009 04:26 PM
