Sponsored by:
Sponsored by: CARiD
Gauge wiring question
Old Aug 5, 2013 | 08:09 PM
mrwickd123's Avatar
I'm waiting on my AEM wideband and I have a boost gauge hooked up to both of my accessory fuses in the driver side fuse boxes (prosport evo boost gauge). Now is it okay to connect multiple wires to a single fuse? If not, What alternative fuse could I use?
Old Aug 5, 2013 | 10:42 PM
WinstonMonty's Avatar
Its ok as long as you are using mini atc fuse taps with the proper voltage fuse in the slots.
Old Aug 6, 2013 | 08:03 AM
tkromer's Avatar
They're fine, gauges use minimal amperage.
Old Aug 6, 2013 | 09:28 AM
mrwickd123's Avatar
so something like this?
If so, do both cables go to the blue connector or does one of them go into the fuse slot?
Old Aug 6, 2013 | 10:02 AM
ikt's Avatar
ikt
both to blue, or, just daisy chain the wires together
by that I mean run a single set to the first gauge, then just split the wiring to the second.
Old Aug 6, 2013 | 07:11 PM
Those arent the mini atc but they look very similar. Just smaller and use mini fuses. Ya you can attach both gauge wires to the blue connector and plug the fuse tap in the fuse box.
Old Aug 7, 2013 | 12:31 AM
mrwickd123's Avatar
Thank you. Also, can I connect two ground wires to the same ground source?
EvoScott95
Evo X How Tos / Installations
Sep 29, 2015 05:35 AM
oliverevoIV
Aug 31, 2015 08:23 AM
Jasoob
May 8, 2012 09:57 AM
cpunlamd
Jun 20, 2010 06:25 PM
NJ_evoIXgsr
Apr 19, 2009 04:26 PM
