AMS Goodies/ Install pics/ vids
Basically when the boost controller tells the turbo too produce less boost (through vacuum) the pill slows this down allowing the turbo to boost longer and it gives you more power.
It must be used with software or you will screw up your motor.
There are lots of options. AMS sells a nice Odyssey battery with hold-downs on an anodized aluminum plate. Of course, if you wanted something a little stronger for the Midwest cold, like I might, you can look here:
http://www.batteriesplus.com/c-97-Od...Batteries.aspx
But you have to buy the hold-down kit extra...
getting my new intake tomarrow
