09+ Ralliart Show and Shine Post your pictures, photoshops, and videos!
AMS Goodies/ Install pics/ vids
Old May 15, 2009 | 12:12 PM
  #31
08Lancer89's Avatar
So I got good news, and bad news. good news is that the install is done, bad news is that the test drive and videos are going to have to wait till tuseday beacause ups dosnt deliver on saterday where im at gay..
The install was very easy, took me awhile beacuse I was just getting over a cold. everything was simply bolt on, only had to cut the one rubber tube i did that with some pvc pipe cutters worked great, I would like to thank Dan at AMS for helping me out and hooking me up with some awsome parts, they sure do look hot, but well see how the ride is tuseday
here are some pics!!!!
all done
Old May 15, 2009 | 01:14 PM
  #32
laflsyl10's Avatar
Pimp
Old May 15, 2009 | 01:17 PM
  #33
bossssman38's Avatar
sexy
Old May 15, 2009 | 01:18 PM
  #34
GiLizILL's Avatar
gratz, AMS ftw
Old May 15, 2009 | 02:15 PM
  #35
08Lancer89's Avatar
hell yeah they make awsome stuff. Next on the list is the FMIC Kit
will post vids when I can
Old May 15, 2009 | 02:55 PM
  #36
Mrbobcat's Avatar
Originally Posted by C H
Basically when the controller tells the too produce less boost (through vacuum) the pill slows this down allowing the turbo to boost longer and it gives you more power.
It must be used with software or you will screw up your motor.
So the boost pill you put in replaces the stock one and has a slighltly bigger dia. to allow for more boost? Also as far as software you are referring to the flash correct? I thought they could do that at a tuning or dyno shop? Any idea what kind of gains to expect from these mods and ballpark what the cost is? Sorry for the noob questions as I've never had a turbo car. Just trying to get an idea if it would be worth it to get the RA and do mods similar to these or just get a car like the wrx or gencoupe that does'nt need mods right away to be in the mid-to low 5's. And yeah I know the rex can get get high 4's to 60 stock, but thats with a redline clutch drop and their having numerous motor failures. Plus the RA looks a little better...
Old May 15, 2009 | 03:01 PM
  #37
elpoole's Avatar
but then you would be in gen coupe and thats never a good thing. You might as well wear looney tunes and hang cute toys on your cell phone.
Old May 15, 2009 | 03:07 PM
  #38
Mrbobcat's Avatar
I don't know, I think the gencoupe is pretty sharp, esp. the GT version in black with the brown leather. The camaro V6 is really starting to grow on me too and they are starting to get some decent times on them now, really close to the gen and you can't say they are a "chick's" car. Just waiting for the hype to die down on them because even the 1LT's are pushing 30k right now...
Old May 15, 2009 | 03:25 PM
  #39
08Lancer89's Avatar
Okay ppl back on topic here,
Goood news ecu will be here tomarrow!!
Old May 16, 2009 | 11:38 AM
  #40
08Lancer89's Avatar
Well it runs,
BUT it only gets 10lbs of boost
something must be wrong wit hteh tune, have to wait till Monday to talk to Dan.
SOUNDS NASTY AS HELL THO!
AND THE BOV IS LOUD AS HELL!!!
not getting 260awhp tho keep u guys posted
Old May 16, 2009 | 12:32 PM
  #41
Indifference126's Avatar
Somebody correct me if im wrong but isnt that what happens when the car overboosts? goes into limp and doesnt go past 10psi? Especially after seeing your other thread with the CEL.
can you reset the ECU by unplugging the battery for a few?
Old May 16, 2009 | 01:00 PM
  #42
C H's Avatar
C H
Here is some good info. It isn't AMS but I don't think they have a post with all the graphs that GST does. Either way they both seem to be good tuners and either you will probably be impressed.
https://www.evolutionm.net/forums/20...ns-o-data.html
http://www.gstmotorsports.com/store/...oducts_id=1050
Old May 16, 2009 | 01:01 PM
  #43
C H's Avatar
C H
Originally Posted by 08Lancer89
Well it runs,
Vacuum leak?
Old May 16, 2009 | 01:51 PM
  #44
08Lancer89's Avatar
No I got a cel and the cel is the Air sensor, I found something else out but I gotta call AMS monday and talk to them.
Old May 17, 2009 | 06:28 AM
  #45
tjac357's Avatar
Did you get the Recaro Sports Package. I read on the AMS website the mini battery couldn't handle all sound systems and was wondering if that was a problem for you.
