09+ Ralliart Show and Shine Post your pictures, photoshops, and videos!
Project Livefast
Old Sep 29, 2012 | 06:14 AM
  #91
Livefast.eu's Avatar
Prepared interior for new freshy good smelling parts
Cleaned and washed.
Started to do meter pod. There is possibility to use OEM radio (without display) or make place for DIM2 player. Havent decided yet, what i will use.
Old Oct 5, 2012 | 04:50 PM
  #92
nunyas's Avatar
kind of looks good as it is though!
Old Oct 28, 2012 | 01:00 AM
  #93
Finished sleeved block.
If you are doing work by your self or with local machineshop, here you can pick up details for measurements, to install sleeves:
http://www.livefast.fi/4b11t/
Old Oct 28, 2012 | 05:00 PM
  #94
TheNEWB's Avatar
Epic. Thread is epic.
Old Oct 29, 2012 | 12:53 PM
  #95
Today i cleaned block from all possible depris, what was left from machining.
Took about hour to get it perfect.
Then i installed oil squirters, Acl bearings, oem polished crank and Arp main bolts. Also checked bearing clearences. All perfect....
Then i had to quit, because i didnt have right bolts to put motor to motor-stand. And also had to do one customer job.
Will continue my engine end of week.
And put motor to good night sleep
We sent some parts to Thermal Coating. So i included my TurboXS downpipe to same shippment. Got it back last week.
Old Nov 3, 2012 | 08:44 PM
  #96
Some progress today. Or not...
Roof cushion was ready. Same material than Audi S-line and Bmw M-sport uses. Just need to give it little more heat, so it´s perfect.
Also test fitted it, so i can know will it look good.
I continued to build engine. Measured all ring caps and things like that.
Then i started assembly pistons and rods. Oh my god those CP Pistons circlips are PITA. Those are a lot thicker, than other brands.
Finally after some hour-two, i realized good method to put those in.
But after i put rod and pin in, other side´s circlips was almost impossible
Tried many hours with different methods, and all what i got was painful thumbs and one lost clip. Then i called it a day. Or should i say morning.
It´s morning here in Finland, so whole night was in garage today....
I will go to sleep now, and think tomorrow, will i order new different clips, or try more with what i have now.....
Old Nov 15, 2012 | 07:11 PM
  #97
DarkSyde294's Avatar
Loving this build.
Old Nov 17, 2012 | 12:21 AM
  #98
Pilars ready. So deepest black alcantara and red stitching.
As you know, pictures dont make justice for things like this. MUCH cooler and blacker in person
Originally Posted by DarkSyde294
Loving this build.
Thanks you sir!
Old Nov 20, 2012 | 07:47 AM
  #99
Laza's Avatar
^^ This is how the car interior SHOULD have looked like, I don't know why Mitsu didn't do anything to differentiate the RA from standard lancers..no colourful stitching, no logos, only the fake CF stripe on the dash, that's it
Old Nov 20, 2012 | 03:23 PM
  #100
We need a update. This is like my crack right now.
Old Nov 21, 2012 | 06:03 AM
  #101
kapitolralliart's Avatar
wow...subscribed
Old Nov 26, 2012 | 11:03 AM
  #102
FourG69's Avatar
Terkkuja Canadasta!
Old Nov 26, 2012 | 05:45 PM
  #103
eug!'s Avatar
Good thing you painted over that white/red color scheme
Old Dec 30, 2012 | 03:17 PM
  #104
Little bit progress....
Steering wheel, shifter and handbrake got highest quality black leather, what is available. Red stitchings was made "double"-style, so those give more grip Noooo. Just looks and feels better.
Painted plastic interior pieces with Black PlastiDip.
First time to try that stuff. It is good, but not for interior parts. After couple months of driving, those will look horrible. Too soft for nails and rubbing.
Old Dec 30, 2012 | 03:19 PM
  #105
...and for THE engine
Cp Pistons´s wire locks was painful. Throwed them to trashcan.
And ordered KrammLox´s SureLox´s. GREAT product! Easy and quik to handle. So, pistons "damages" are NOT from SureLox assembly. All made with Cp Pistons´s locks. Now i know, why Cp Pistons had started distributing KrammLox´s products too....
Measured all possible clearances again, and assembled pistons and rods to block.
Now i need to continue customers cars, and start collecting more money Need a lot more parts.
Just to let all know, deathline for car is April. So let´s see how wallet will handle that Car will running then, no matter of what. Just have to skip some parts and modifications, and do those next winter.
