09+ Ralliart Show and Shine Post your pictures, photoshops, and videos!
Aftermarket Radio Thread
Old Jun 21, 2012 | 09:36 PM
RalliAaron's Avatar
I know alot of people would like to see others' set ups, to give each other an idea of what looks the best, OEM "look", best functionality, etc. So lets see what your set up looks like, and maybe provide some information on it, such as:
1. Brand & Model
2. Pros & Cons
3. Functionality(Easy to use/rough)
4. Cool Features
5. Price Range(Everyone wants to know this)
And also provide a picture of your set-up. I will post some of mine in the next few days, as I just got my car back & waiting for the double din dash kit to get here.
Old Jul 16, 2012 | 10:31 AM
brains613's Avatar
Just bought my RA, and this thread is relevant to my interests. But I can see that it didn't really get off the ground. Maybe a bump will help...
Old Jul 21, 2012 | 05:16 PM
RallyLancer95's Avatar
Does anyone know if you can install the rockford fosgate system that comes in some lancers aftermarket?
Old Jul 25, 2012 | 04:25 AM
carbonair's Avatar
Innovatek w72gps
pro- Whole system is PC, so can be corrupted to put any program you want. Change modes and you are back into a simple template ( radio, nab, bluetooth). system sounds great. Can change everything about the sounds, the individual HZ the sound comes out at even.
fully loaded with BT, NAV, Rear view,
con- its a PC, system can be slow at times. There is a glitch in the system when starting it up, but as long as you have a rear view connected it resolves the problem other wise its just a slight pain. ( when starting you have to change programs before being able to listen to music. )RVC solves this.
System could be a little simpler. I hate going into the PC mode. Not something I want to deal with while driving, should be a lock while moving so that it stays on the simple screen.
209$ off of amazon. 299$ off ebay, and suggested retail of 650$
Has wifi so its automatic updates when around wifi, or plug in a internet stick and do it that way
Old Jul 25, 2012 | 04:27 AM
carbonair's Avatar
^rallylancer^ yes u can install it, metra I believe actually sells a plug and play harness or this. I forget how much work it otherwise takes to install, but there is a DIY somewhere on this web site
Old Jul 26, 2012 | 01:07 PM
brains613's Avatar
Carbonair,
Did you do the install of the Innovatek yourself? Do you still have steering wheel controls? How does the Bluetooth work?
Old Jul 28, 2012 | 01:34 PM
carbonair's Avatar
yes i installed it myself. ran the rya cable for the rear view up to the deck. I used a multi meter to find which radio harness wire turned on when put in reverse. tapped into that instead of running a separate cable front to rear.
Blue tooth works awesome. People have had no complaints while talking to me threw it.
Steeringwheel controls- it CAN work, but haven't figured it out. Short of buying the 125$ after market adapter, I am trying to figure out how to wire up a can bus.
Id give the deck a 7/10.
It uses windows and windows can actually be accessed. This is a bit of a pain when driving as then the buttons on the touch screen get very small. As long as you stay in "simpleton" mode its great
Old Jul 28, 2012 | 03:51 PM
brains613's Avatar
Cool. I might just pick a couple up. I appreciate the info. I may send you PM for some info a bit later, if that's cool.
Old Jul 30, 2012 | 05:47 PM
Big Steve's Avatar
1. Brand & Model: Pioneer AVH-P4400BH
2. Pros & Cons: I love this entire unit. Everything is good about it. The selling points for me were the 4V amp preouts and 8-band equalizer. I also have the PAC adapter that allows me to keep my steering wheel controls. I have had it now for 3 weeks and have found no cons with it.
3. Functionality: This is very easy to use. I have used single din units for all of my cars and finally decided to break down and buy something nice. The touchscreen is spot on which makes it extremely easy to use!
4. Cool Features: DVD plays while driving with the help of a relay.
5. Price Range: $429.00
Attached Thumbnails Aftermarket Radio Thread-img_1345new.jpg   Aftermarket Radio Thread-img_1344new.jpg   Aftermarket Radio Thread-img_1346new.jpg   Aftermarket Radio Thread-img_1348new.jpg   Aftermarket Radio Thread-img_1350new.jpg
Old Jul 31, 2012 | 07:48 AM
brains613's Avatar
Big Steve, what dash kit do you have?
Old Jul 31, 2012 | 08:30 AM
Big Steve's Avatar
I have the one that is made by Scosche. I am happy with the fitment.
Old Jul 31, 2012 | 11:21 AM
brains613's Avatar
That's what I wanted to know. Thanks for the info!
Boosted Tuning
59
May 12, 2011 07:56 AM
Addicted4Life
Northwest Region
Jan 28, 2008 10:49 PM
Kins
42
Jan 22, 2008 07:13 PM
nils
46
Jun 10, 2005 09:56 PM
tpm17
22
Jun 27, 2003 08:57 AM
