evo 8 2.2L efr 8374 build!
wont start, i have an extra connector pictured below maybe thats it? i also cannot build oil pressure, that could cause a no start with the protection software. pulled the plugs, unplugged the injectors and cranked it a ton! oil filter is still dry!
That connector is the o2 housing oxygen sensor connector. Bolts to the valve cover with a steel tab. Should be fine being open.
I pull the plugs, disco the injectors/fuel pump, and pull the fuse on the ignition.... and crank the engine over until you build oil pressure.
if that's not working I would drain the oil and pump it through the oil feed line (from the oil filter housing) and fill the engine with oil that way...then you've ran oil through the oil pump into the pickup and finally into the pan.
Then try cranking again to build oil pressure.
I would disable all "safety" tables that might prevent you from finding the true culprit. Check for spark, fuel, and compression.
its weird how it wont build pressure, its the original engine and i havent dropped the pan or even removed the timing belt. all i did was drain most of the oil to change the turbo oil drain and put a new filter on after i topped the oil off. ill try and figure out how to disable the safety.
tomorrow ill button it all up to start it and hook up the laptop and see what i get. if it still gives me trouble, ill slap my aem in and see if it starts on that. if it starts on aem i know its an engine management issue and not a mechanical/wiring issue.
ill check continuity and the pinouts to make sure they are correct, but i know the oil is still not pumping. after pulling out the plug on the side of the housing and pumping 1/2 qt of oil thru and cranking for another full 90 seconds, the oil filter was only half full.
im not worried about the oil though. when i swapped a built block in my 07 sti it just would not build pressure no matter how much i cranked. fired it up and it had full pressure in 2 seconds. ill get it, i just need time!
for building oil pressure - (if you're having trouble)
isolate the fuel/ign system
remove the oil filter
crank the engine over until you have oil coming out from the oil filter housing (5-10seconds)
refit oil filter and crank.
Sometimes the oil filters will stop/restrict the oil going into the engine when there is Air in the system
checked the wiring to the oil pressure sensor and everything else i added and its all good. car fired right up on the stock ecu and the oil light went out so i assume im getting oil pressure now. when i crank it on the proefi, it does feel like its firing a bit off so maybe something is configured wrong in the map. i cant get the cable to communicate and the link for the driver is down on their website. ill try and get the driver so i can pull the map off the ecu to look at it.
edit: map on the ecu appears to be wrong, cant get the correct one on because the cable wont communicate. keep getting dll errors.
waiting on an email with a missing file for my ecu. in the mean time i found the perfect upper radiator hose for the mirage radiator! its for a 2003 acura rl. goodyear part# 60947. the one typically sold with evo 7 radiators (98-02 mirage) was 2" too short. i also had to use a mirage radiator cap, the stock evo cap is a bit different and will not fit.
anything that is a weak link in my setup in anyones opinion? my car must do it all well. im not interested in a drag car or a full blown track car. i know there are compromises when you try to excel at different types of racing, but im trying to minimize them. it needs to corner well, stop well, and haul *** in a strait line. i also dont want massive lag or terrible driveability. im not sensitive, so be honest.
longblock
10:1 class one built 2.23L 4g64
manley turbo tuff billet 94mm crank
manley turbo tuff 156mm rods with 625+ bolts
custom arias pistons with heavy pins
block is filled to the water pump holes and o-ringed
headgames race head with ferrea valves, kiggly springs and hla
buschur modded stock pan
custom gsc cams (274/274, 236@.040"/236@.040", 12mm/11.7mm lift)
ams style balance shaft delete
hot stuff
full-race twinscroll t4 kit
2 mvs wastegates with 1.4 bar springs
borg warner efr 8374
maperformance fabbed varex catback
cold stuffhomemade 4" intake with biggest amsoil air filter i could find
anodized ets 4" intercooler
ets uicp
ams f1-i intake manifold
fullblown 70mm throttle body
drivetrain
quartermaster street twin
shep ultimate ratio 5 speed with billet output shaft
shep stage 2 t/c with wavetrac
fuel
integrated engineering surge tank
2 bosch 044's
fic 2150's
stm fuel rail
russell twist lock -8 feed and -6 return
weldon fpr
engine management
proefi 128
fuel pressure sensor
oil pressure sensor
ethanol content sensor
5 bar map sensor
gm ait
color can display
suspension
works/ohlins r/t's with revalved rears and swift 10k/12k springs
perrin offset psrs
whiteline roll center kit
18x9.5 enkei pf01 with 275/35R18 toyo r888's
whiteline sway bars
brakes
dba 5000 front/dba 4000 rear
technafit lines
ferodo ds2500 pads
ducts in the future
longblock
hot stuff
ets uicp
drivetrain
fuel
2 bosch 044's
fic 2150's
stm fuel rail
weldon fpr
engine management
proefi 128
oil pressure sensor
5 bar map sensor
gm ait
color can display
suspension
perrin offset psrs
whiteline sway bars
brakes
technafit lines
ferodo ds2500 pads
ducts in the future
