evo 8 2.2L efr 8374 build!
way overdue, but better late than never! right now im getting the turbo kit and engine management all sorted out on the stock longblock. i dont want too many things going on at once and i dont want to troubleshoot issues and stuff on a fresh motor.
if anyone wants any specific pics or info, just ask and ill post it up.
here are the essentials.
longblock
10:1 class one built 2.23L 4g64
manley turbo tuff billet 94mm crank
manley turbo tuff 156mm rods with 625+ bolts
custom arias pistons with heavy pins
block is filled to the water pump holes and o-ringed
headgames race head with ferrea valves, kiggly springs and hla
buschur modded stock pan
custom gsc cams (274/274, 236@.040"/236@.040", 12mm/11.7mm lift)
ams style balance shaft delete
hot stuff
full-race twinscroll t4 kit
2 mvs wastegates with 1.4 bar springs
borg warner efr 8374
maperformance fabbed varex catback
cold stuffhomemade 4" intake with biggest amsoil air filter i could find
anodized ets 4" intercooler
ets uicp
ams f1-i intake manifold
fullblown 70mm throttle body
drivetrain
quartermaster street twin
shep ultimate ratio 5 speed with billet output shaft
shep stage 2 t/c with wavetrac
fuel
integrated engineering surge tank
2 bosch 044's
fic 2150's
stm fuel rail
russell twist lock -8 feed and -6 return
weldon fpr
engine management
proefi 128
fuel pressure sensor
oil pressure sensor
ethanol content sensor
5 bar map sensor
gm ait
color can display
suspension
works/ohlins r/t's with revalved rears and swift 10k/12k springs
perrin offset psrs
whiteline roll center kit
18x9.5 enkei pf01 with 275/35R18 toyo r888's
whiteline sway bars
brakes
dba 5000 front/dba 4000 rear
technafit lines
ferodo ds2500 pads
ducts in the future
longblock
hot stuff
ets uicp
drivetrain
fuel
2 bosch 044's
fic 2150's
stm fuel rail
weldon fpr
engine management
proefi 128
oil pressure sensor
5 bar map sensor
gm ait
color can display
suspension
perrin offset psrs
whiteline sway bars
brakes
technafit lines
ferodo ds2500 pads
ducts in the future
how the car is sitting right now. i need a couple clamps, need to plumb the oil pressure sensor and i need to finish up some wiring then it "should" run. one thing i need to figure out is a licp. nobody makes one and i cant weld. ill have to try and find a decent fab shop and get one made.
some random shots of things i did "differently".
im running 2 catch cans, both are allstar catch cans that you can get from amazon for $70 each. these and the moroso cans work as good or better than anything out there. its very tight under the hood so i put one in front of the drivers side tire.
i also drilled and tapped the block in 2 spots by the balance shaft bump. im going to try and use them for crankcase ventilation. if they blow too much oil out, ill plug them up.
also went with a 98-02 mirage radiator. the upper hose is a strait shot lik an evo 4 5 6 and the mounting pins are the same as an evo. one upper mount lines up, the other is offset. i made new straps that you can see in the pics in the previous post.
moved my battery to the trunk and used the stock tray bolts to mount my ethanol content sensor. just a strip of aluminum with a 60 degree bend and a few holes.
very nice.
Just so you know... this is where those ECU's come from
http://mcs.woodward.com/products/Con...e/ECUhardware/
very nice.
wrapped up the wiring, have 2 faults, one for low ethanol content and one for low oil pressure.
ethanol content read as 6% which is most likely correct as our 93 octane has "up to 10% ethanol".
oil pressure was low because the sensor isnt hooked up and i didnt start the engine.
tomorrow i have to install the oil pressure sensor, fill the oil and coolant, bolt the valve cover down and tighten the exhaust. hopefully it runs.....
mmmmm proefi 128
