evo 8 2.2L efr 8374 build!
I am considering a BR pan on my 2.4 rebuild. It is a good price and appears to work. The AMS/Moroso pan costs too much considering the fitment issues. At that price point I would want it to be perfect fitment.I would also chose a bigger sprung hub clutch like a os Giken or HKS GD Max Pro. I hated my 7.25 clutch for a street car. I drove too many miles in traffic the clutch had to be rebuilt 3x's in 15K miles. It shifted awesome though.
front.
rear.
soft springs I guess. I run 850's in the rear and I'm nearly out of thread for ride height adjustment (lowering it)
How do you mean pre-loaded to 198mm? you compressed the rear springs .200" I don't remember reading that... mind snapping a pic of your manual?
I just go until the spring doesn't rattle, then do a full turn. Do you have a LOT of weight in the rear of your car?
There is a limit line where the threads stop for about 4mm and then continue. That's the highest you raise the car.
Take a picture of the car from the side and from the rear and LOW.
measure your ride height from the CENTER of your axle nut to your quarter/fender vertically.
A quick way to check is 1.5 to 2 fingers up front (or see that the LCA's are parallel)
the rears I've had set to about 1 finger gap.
The rear will be lower than the front and the gap won't be the same. The suspension geometry limits you up front.
let the e-brake off, bounce the springs, and roll the car back and forth. My rear shocks are adjusted maybe a half an inch lower than yours.
do you have a 6" spring in the rear? or is than an 8"
springs are 8" front and back. i forgot what i set the ride height too, but i think my definition of low and others is pretty different. you got a pic of your ride height?
all the corners are within 1/8". on one of the fronts it took 2 full turns more than the other, i dont remember which side it was though. im just getting it close and ill have my alignment guy corner balance it.
btw, whats with the extra turns on the rf?
