Innovation and EVOlution in the aftermarket - the NEW best MBC for EVOS!
Old Sep 13, 2005 | 07:41 AM
  #136
fsugatorbait's Avatar
Originally Posted by coastal96
Laf -- I had the same issue when I first installed it and was trying to dial it in. I would turn it a few clicks at a time and it kept hitting only about 15 or 16 psi. Then I finally went under the hood and cranked the hell out of it . . . . 20 - 25 clicks maybe . . . to get upto 20 psi. My brother could see me from the passenger seat and he said it looked like I was trying to twist off a bottle cap
For those who have the unit in, how is it working out for you? If you had a MBC prior is this holding boost better/worse?
Old Sep 13, 2005 | 07:50 AM
  #137
Mike@Forge's Avatar
Here is a size comparison photo of the units.
Old Sep 14, 2005 | 05:06 AM
  #138
Mike@Forge's Avatar
For anyone concerned over the best way to install a boost controller......
........Al/Dynoflash and I spent about an hour on the phone yesterday and part of our conversation was concerning the best way to setup/install a manual boost controller of the lock-ball and spring type. (Like our new Unos.)
Here are the results:
Turbo Outlet
This is the standard method of connecting a boost controller and arguably the safest.
If there were no boost controller at all being used in the system, this is the method REQUIRED to be used.
Without a boost controller, you ONLY want positive pressure acting on the diaphragm of the actuator. NOT pressure and vaccum as would occur when connecting the source to the inake manifold. The vacuum can pull on the diaphragm of the actuator pulling it into the unit's vacuum nipple and potentially tear it.
When a boost controller is used, this is not an issue as the vacuum is pulling on the ball of the boost controller instead of the diaphragm of the actuator.
(this is only the case for a lock-ball and spring type manual controller)
This also allows the boost controller and blow-off/bypass valve to have their own references improving the response of each individually.
Intake Manifold/Sharing with BOV
Sourcing the reference from here MAY provide a very slight improvement in repeatability of boost, however, this is a less safe method of installing the boost controller and actually leads to another issue that can hinder the performance of the car.
First and foremost, the Bypass/Blow-off valve must always have a intake manifold reference. NEVER reference the valve from the turbo outlet. Please don't confuse that with what I am refering to here.
If the boost controller and BOV share that same reference from the intake manifold, they are essentially sharing the same volume of air (pressure/vacuum).
When the boost controller (lock-ball-and-spring type) actuates, meaning when the spring allows the ball to come off of it's seat and send the pressure signal to the actuator, some of the "shared" pressure helping to hold the bypass/blow-off valve closed under boost is now momentarily diverted to the wastegate actuator potentially causing a "flutter" in the seal of the bypass valve and a slight loss of boost pressure altogether within the system.
If the boost controller and BOV each have their own individual reference from the intake manifold, the possibility for this flutter is greatly decreased, however, it may still exsist to some extent because both references are sharing the intake manifold pressure.
Al and I have seen this issue on mutiple vehicles and sourcing the boost controller directly from the turbo eliminates it completely.
In short, the best method will be connecting the boost controller directly off of the turbo outlet or anywhere on the intercooler piping BEFORE the throttle body.
Boost Controller
Positive Pressure Only
(Turbo Outlet)
Bypass/Blow-Off Valve
Positive Pressure AND Vacuum
(Intake Manifold)
Old Sep 14, 2005 | 05:14 AM
  #139
GOKOU's Avatar
Boost Controller
(Turbo Outlet)
(Intake Manifold)
I currently have my vaccum after the TB going to my bov as well as my AMS BC. This might sound stupid but where is the turbo outlet? Are you referring to the stock lower pipe where there use to be a nipple? Where do I tap if I have a BR lower pipe? I like to try this out and see if it makes any difference. I'm not that a lot of people are running the same as I am where the BC and bov vaccum is after the TB.
Thanks
Old Sep 14, 2005 | 05:51 AM
  #140
MM Racing's Avatar
I have mine mounted in the BOV line and am experiancing some flutter/taper, next experiment is going to be to try the turbo outlet again and see how things change. I will update here when it is done, with no other changes besides changing locations.
Old Sep 14, 2005 | 06:27 AM
  #141
Mike@Forge's Avatar
You can tap the reference anywhere from the outlet of the turbo to anywhere before the throttle body.
Obviously the shortest reference to connect to the actuator would be from right in front of the turbo.
Old Sep 14, 2005 | 07:31 AM
  #142
GOKOU's Avatar
Cool! Let me know because I will need to drill a hole in the intercooler pipe and don't want to do it if the results are nearly the same.
Old Sep 14, 2005 | 08:32 AM
  #143
DynoFlash's Avatar
I have 5 black in bound
Old Sep 14, 2005 | 08:43 AM
  #144
hardt45's Avatar
Al,
Just paypal'ed you - I'd like to get one of the 5 black ones you have coming if possible. Thanks!
Chad
Old Sep 14, 2005 | 01:11 PM
  #145
trinydex's Avatar
that is one fine piece of information.
Old Sep 14, 2005 | 02:10 PM
  #146
Mike@Forge's Avatar
I THINK I might have more Unos' coming in on a shipment on Friday, but I won't know for sure until it arrives and I unpack it.
Once they're here, I imagine they will sell quickly so get on waiting lists with Al, Buschur, and GSC as soon as you can.
Old Sep 14, 2005 | 02:56 PM
  #147
2BARevo's Avatar
hey Al,
just paypaled you for one of the incoming 5 black ones. thanks!
Old Sep 15, 2005 | 03:08 AM
  #148
alicea8541's Avatar
Al, cash is inbound for a black one.
Old Sep 15, 2005 | 03:13 AM
  #149
jxn evo 8's Avatar
sweet
Old Sep 15, 2005 | 05:57 AM
  #150
GOKOU's Avatar
Man these are selling like hot cakes
