Innovation and EVOlution in the aftermarket - the NEW best MBC for EVOS!
Old Sep 12, 2005 | 07:48 AM
  #121
Mike@Forge's Avatar
Originally Posted by bigboybusa
I am running about 1.4 kg/cm
If this in on the stock ECU, then you are at the limit that the ECU will allow in terms of boost.
Your best bet would be to just run 20-21 PSI until you get a reflash or some other form of tuning.
Old Sep 12, 2005 | 09:16 AM
  #122
Mike@Forge's Avatar
HOLY COW.
You guys are animals.
The Black units are sold out already.
More are on the way, but get in touch with Al/DynoFlash and Buschur as they will soon be receiving some more.
Old Sep 12, 2005 | 07:52 PM
  #123
Mike@Forge's Avatar
Black Unos pictures!
Old Sep 12, 2005 | 08:16 PM
  #124
2BARevo's Avatar
are they sold out to the people that gave you information? I never got a call from you guys. I hope there is one saved for me. I will call you tomorrow. damn, i've been waiting on the black ones too.
Old Sep 13, 2005 | 06:05 AM
  #125
fsugatorbait's Avatar
You needed to call him to get your name on the list.
Mike, what spring comes installed?
Old Sep 13, 2005 | 06:27 AM
  #126
Mike@Forge's Avatar
The softer of the two included spring comes installed in the units. The stiffer spring is included in a small bag in the packaging.
Old Sep 13, 2005 | 06:34 AM
  #127
coastal96's Avatar
What is the difference between having the softer vs. the stiffer spring installed?
Old Sep 13, 2005 | 06:37 AM
  #128
Mike@Forge's Avatar
Each one has it's own range of adjustment it will allow.
The actual boost pressure allowable with either spring, however, will be entirely dependant upon the base spring pressure of the wastegate actuator or external wastegate used in the given system being tuned.
  #129
MM Racing's Avatar
Well so far I can tell you that you will more then likely want the stiffer spring. I left the soft one in it just for testing to see how it worked and the adjustment is very course, it took me 5 clicks to raise the boost 1 psi.
Otherwise though this controller kicks ***. Nice bracket and construction, wish I would have waited for the stealthy version though.
Old Sep 13, 2005 | 06:41 AM
  #130
Mike@Forge's Avatar
The amount of "clicks" required to turn up the boost any given amount was done intentionally to provide the most precise level of adjustment while retaining the detent/ratcheting feature.
Any fewer "clicks" wouldn't allow for such minute levels of adjustment if required.
Everything was done intentionally!
Old Sep 13, 2005 | 06:47 AM
  #131
So would you recommend the hard or soft spring for use with near stock boost levels with the stock actuator?
Old Sep 13, 2005 | 07:15 AM
  #132
Mike@Forge's Avatar
Either will work.
Soft
If you use the softer one with the stock actuator, you will need to adjust it towards the higher side of it's range.
Stiff
If you use the stiffer one with the stock actuator, you will need to adjust it towards the lower side of it's range.
Old Sep 13, 2005 | 07:17 AM
  #133
MM Racing's Avatar
Yeah I understand the reasoning and I think it was a good idea. Wasn't trying to mar the product at all.
Old Sep 13, 2005 | 07:26 AM
  #134
Mike@Forge's Avatar
I know.
I just wanted everyone to know that we incorporated feature intentionally.
Old Sep 13, 2005 | 07:34 AM
  #135
coastal96's Avatar
Laf -- I had the same issue when I first installed it and was trying to dial it in. I would turn it a few clicks at a time and it kept hitting only about 15 or 16 psi. Then I finally went under the hood and cranked the hell out of it . . . . 20 - 25 clicks maybe . . . to get upto 20 psi. My brother could see me from the passenger seat and he said it looked like I was trying to twist off a bottle cap
Either will work.
Soft
Stiff
I'll stick w/ the softer spring for now then
