Innovation and EVOlution in the aftermarket - the NEW best MBC for EVOS!
Old Sep 11, 2005 | 03:59 PM
  #106
Mike@Forge's Avatar
Originally Posted by aznevo
mike are u going to add a vacuum section with mbc and if u do i will buy it now and sell the ams.
As of right now, vacuum line will not be included for the current price. The price will go up slightly if we include vacuum line.
Old Sep 11, 2005 | 05:10 PM
  #107
2BARevo's Avatar
Originally Posted by Mike@Forge
I can put your name on a list, but I know at least 3-4 are spoken for already and I only think I'm recieving 10 in the first shipment.
Not too sure until the shipment actually arrives.
mike@forge,
Put me on the list for one of the black ones. pmed you too.
Chris
Old Sep 11, 2005 | 05:14 PM
  #108
FluxedSpeed's Avatar
Mike, I would also like to be added on the list for one of the black ones if a spot is available, thank you.
Old Sep 11, 2005 | 07:22 PM
  #109
Mike@Forge's Avatar
Ok, folks, I'm not keeping a running tab of screen names. You will need to contact me via telephone and provide me with your information.
Old Sep 12, 2005 | 12:33 AM
  #110
bigboybusa's Avatar
Mike@forge,
I installed the MBC today, it is great, I did have to put the softer spring in to be able to set it. My question is, I think i am hitting fuel cut at 1.4 kg/cm? That shouldn't be happening?
A little info about my car, RNR SS intercooler hard piping, 3" high flow cat, 3" exhaust, HKS SSQBV, and K&N.
Old Sep 12, 2005 | 05:36 AM
  #111
Mike@Forge's Avatar
Fuel cut is based on the tuning of the stock ECU or the range of the fuel system. The boost controller only turns up the boost. It doesn't create fuel cut.
Old Sep 12, 2005 | 07:19 AM
  #112
coastal96's Avatar
I installed it the way Mike recommended . . . pressure reference from the turbo . . . and all is well
It would have been nice if some vacuum hose was included but it wasn't a big deal to run to Pep Boys and get the additional hose I needed.
Old Sep 12, 2005 | 07:20 AM
  #113
bigboybusa's Avatar
Ic, well I am getting some sort of cut off of boost. I will be at full throtte and it will suddenly it will jerk, and shut off. It doesn't do it all the time but pretty often.
Old Sep 12, 2005 | 07:23 AM
  #114
Mike@Forge's Avatar
That's fuel cut then.
It's plainly obvious when it happens. It's actually quite disturbing how hard the car jerks when it happens too.
The only way around it is a tune/reflash that removes it, raises it, or a fuel system that is not maxed out.
In all likelihood, you need a tune/reflash, because if it was your fuel system, you would be experiencing knock and the motor could be damaged consequently, so I'm almost positive it's just your tuning.
You will just need to run lower boost until you get it taken care of.
Old Sep 12, 2005 | 07:25 AM
  #115
fsugatorbait's Avatar
What psi are you hitting? Did you have a MBC installed previously, if so was it set the same?
Mike, when are you expected to have the black available?
Old Sep 12, 2005 | 07:26 AM
  #116
Mike@Forge's Avatar
Today!
But don't expect them to last long.
Old Sep 12, 2005 | 07:29 AM
  #117
Today!
lol...mind giving me a number so I can call you?
Old Sep 12, 2005 | 07:30 AM
  #118
Mike@Forge's Avatar
407-447-5363
Old Sep 12, 2005 | 07:32 AM
  #119
bigboybusa's Avatar
I am running about 1.4 kg/cm
Old Sep 12, 2005 | 07:40 AM
  #120
407-447-5363
Thanks again Mike.
