smelly a/c ?
Old Aug 16, 2006 | 08:38 AM
Bigl4201's Avatar
smelly a/c ?
does anybody else experience a weird almost mildewy smell when the A/C is on ? its not horribly bad but it smells funny enough to notice. I just noticed this last night and I am just wondering if it is "normal" ? And if anybody else has experienced this. thanks
Old Aug 16, 2006 | 08:42 AM
prind0's Avatar
I get a weird smell for about 5 seconds when I first start up the car during the day. After that it smells normal again.
Old Aug 16, 2006 | 08:43 AM
Noize's Avatar
EvoM Administrator
Its a Mitsu thing. My wife's Montero used to do that too. It happens when you switch from just fan air to A/C air sometimes. I hate it.
Old Aug 16, 2006 | 08:46 AM
Bigl4201's Avatar
i figured that maybe it was a mitsu thing but thanks for the responses guys ! I just wanted to make sure it wasnt just my car. But what i find kind of odd is that it just started doing this at 4k miles, i dont think it was doing this when i first got the car. But then again maybe i just didnt notice it.
Old Aug 16, 2006 | 08:52 AM
PA-silver03evo's Avatar
All AC systems do this. Its normal. BG sells stuff called Fridgi Fresh that you can spray into the system with it on that will make it smell better will even kill any mold or bacteria that could have formed from the dampness.
Old Aug 16, 2006 | 08:59 AM
Bigl4201's Avatar
perfect , thanks for the tip !
Old Aug 16, 2006 | 09:49 AM
confusionisbad's Avatar
Has anyone tried this stuff mentioned above with success?
Old Aug 16, 2006 | 11:06 AM
SLVROZ_03's Avatar
I've noticed more of that problem lately in my lancer OZ. Anything to do with the in-cabin air filter??
Old Aug 16, 2006 | 11:11 AM
~EVILEVO~'s Avatar
the problem is that if you just shut your car off with the AC on you can get condensation in the lines and such, a good way to prevent the smell is to shut the AC before shutting of the car.
i.e. turn the fan on full blast till the air goes warm, before turning of the car
good luck.
Old Aug 16, 2006 | 11:24 AM
PKEVO8's Avatar
usually that also happens if you leave your air off for long periods of time. Air just sits there until you turn it on, and you usually get an odd smell. I usually just leave my fan on 1 just to keep air circulating through the system whenever i drive.
Old Aug 16, 2006 | 11:47 AM
glgz's Avatar
I don't have any odor but I notice if I have my air on going through the carwash I get a little water leaking in on the passanger side floor up under the dash. I would imagine if water can get in you could get an odor.
Old Aug 16, 2006 | 12:26 PM
silvrevo's Avatar
I had this back in 2003. Mits had some flyers in thier waiting room. Its a can of odor Be Gone or somthing. They spray it in the ac somehwere.
Its from build up of mold. Ick
But it did work for me,, check out your Mits parts department.
Old Aug 16, 2006 | 07:21 PM
heavens turbo's Avatar
good ol' R-134a and the recirc button will cause the dirty sweatsocks smell
Old Aug 16, 2006 | 07:23 PM
Cabo's Avatar
good luck.
+1
Old Aug 16, 2006 | 08:22 PM
tirbolag9's Avatar
i just turn on the heater after using the a/c and let the fan blow to evaporate the cold air. i usually do this when letting the car cool down after driving.
