where to tap for meth jet???????
Old Nov 9, 2006 | 02:58 PM
Evoryder's Avatar
possible
Old Nov 16, 2006 | 08:29 PM
snailedhatch's Avatar
you really shouldn't install it in or close to the throttle body if you are using one nozzle. Some people use one right after the IC to focus on cooling the the charge air and another one near the throttle body to help take heat out of the combustion chamber.
Old Nov 16, 2006 | 09:00 PM
Evoryder's Avatar
check snowperformance.net ...i think they know a thing or two about methanol injection...however, that is how i have mine setup at the moment
Old Nov 25, 2006 | 05:08 AM
ItalianEvo's Avatar
Is there a problem tapping the jet BEFORE the blow-off valve ?
I think that some water/meth is going outside through the valve, every time it'll open... correct ?
Old Dec 15, 2006 | 04:27 PM
BoostWhore's Avatar
what if u have the stock upper pipe with a samco coupler... can u tap it in the metal portion right after the bov port and before the upper coupler or would a new hardpipe be the best
Old Dec 15, 2006 | 06:43 PM
C6C6CH3vo's Avatar
I just cut the last "L" piece in half before it bends into the TB, and joined them together with a thinwall. 2.6" titanium peice about 6 inches long. Provides a nice place to thread the nozzle in to. Tbolted it up on each side and good to go, the rubber duct emains the same shape but has a titanium insert. Also keeps it opened for more flow
Although titanium is corrosive under methanol - it just doesn't have time to contact it.
ignoe the top photo
https://www.evolutionm.net/forums/sh...08&postcount=7
Old Dec 15, 2006 | 06:56 PM
SlowCar's Avatar
you need one of this axial mount:
https://www.evolutionm.net/forums/at...7&d=1141885522
https://www.evolutionm.net/forums/at...8&d=1141885533
Old Dec 20, 2006 | 04:44 PM
BoostWhore's Avatar
nice piece there, where do u get it from?. is it to far back to put it back in the hard portion
pcamara17
May 4, 2021 08:20 PM
6466evo
Jan 18, 2015 05:22 AM
ranz
12
May 20, 2011 01:37 AM
mt057
11
Apr 24, 2011 11:28 AM
EvoJoeIX
Mid-Atlantic Region
12
Aug 2, 2008 09:45 PM
