Nitromethane Q&A..
Old Aug 13, 2007 | 02:41 PM
  #31
Ultimate CC's Avatar
I am just wondering cause theres no way I would spray that much nitro into my car...unless it was a super small jet...
Old Aug 13, 2007 | 03:17 PM
  #32
Richard L's Avatar
Our customer just went ahead and did it, as crazy as it may sound. He ended up buying a few sets of valves and holders, just loved the power while it lasted- it is not that bad, I believe it is about 20 dollars a set.
If each set can last two months, and it costs 20 dollars, it well worth the laid out if the gets good power from it.
Old Aug 13, 2007 | 03:37 PM
  #33
Richard L's Avatar
more of his set up:
Old Aug 13, 2007 | 03:39 PM
  #34
SlowCar's Avatar
why double 100u filteration?
Old Aug 13, 2007 | 03:55 PM
  #35
Richard L's Avatar
The 100um is followed by a 30um filter. We always insist this for port injection.
Old Aug 13, 2007 | 04:03 PM
  #36
SlowCar's Avatar
nice.....direct port injection...
will be real nice with the aquamist hfs-6 sequential sHSV setup
Old Aug 13, 2007 | 05:49 PM
  #37
wow that looks like fun...wish i got to playin with nitro like that...thats got to be making serious power...
Old Aug 13, 2007 | 06:52 PM
  #38
94AWDcoupe's Avatar
So how much extra power did it make?
And you are saying you can buy the pump seal parts separate now?
Old Aug 13, 2007 | 07:06 PM
  #39
SlowCar's Avatar
when i got my aquamist/shurflo pump, it came with 8 page instruction in yellow paper:
the replacement part looks from the exploded diagram to be key #5, bypass valve and discharge valve assembly.
on page 7/8:
SERVICE KITS
Kits are readily available to repair standard 8000 series pumps. Repair kits include simple illustrated instructions allowing easy installation. To insure that the correct kit is received the model numbered and all name plate data must be included with the order. Contact s SHURflo distributor or SHURflo directly to order the necessary repair kit.
Old Aug 14, 2007 | 05:39 AM
  #40
bnice01's Avatar
I guess I will give it a shot and post results but i am just using 8% nitro 90% meth 2% oil (using the rc stuff the jug says 30% nitro 60% meth 10% oil)
also the percents are rounded it off so dont bust my *****
if you think about it the lube is going to be a very very small amount, I am using 32oz of the rc stuff to every 96 oz of 100% meth (more meth will "dilute" the oil), so that is going to be in oz:
-9.6 oz (nitro)
-3.2 oz (oil)
-115.2 oz (meth)
I posted the part # for the seals as well as a good distributor on the srtforums but the post is deleted
there are couple different seals out there for the 8000 series pumps ones that can with stand 100% meth to ones that can barely take 25%. I learned the hard way about 1 1/2 ago LOL
Old Aug 14, 2007 | 05:50 AM
  #41
Evoryder's Avatar
good info
Old Aug 14, 2007 | 05:57 AM
  #42
bnice01's Avatar
richard DAMN man thats a nice setup
Old Aug 14, 2007 | 08:19 AM
  #43
Evoryder's Avatar
if you think about it the lube is going to be a very very small amount, I am using 32oz of the rc stuff per gallon of meth (more meth will "dilute" the oil), so that is going to be in oz:
-9.6 oz (nitro)
-3.2 oz (oil)
-115.2 oz (meth)
were there not mixed reviews about adding oil and passing it through a shurflo pump...
Old Aug 14, 2007 | 08:46 AM
  #44
SlowCar's Avatar
Alfa Aesar 2006 - 2007 catalogue
Nitromethane 98+%
100g = $17.20 - 88.5ml
500g = $36.60 - 442.48ml
2500g = $77.20 - 2212.39ml
Old Aug 14, 2007 | 10:15 AM
  #45
dudical26's Avatar
Richard - Have you tested the effects of smaller amounts of Nitro on the pump parts?
Maybe 80/20 meth/nitro
Also how do the rest of the Aquamist parts hold up to nitro (HSV, Flow sensor, lines, nozzles, etc...)
In that old thread on the aquamist boards you mentioned placing a piece of aluminum in some nitro but never posted the results.
